So to start off this system has been at the same settings for the longest time with no problems.
Today I started up Prime95 to test temps because summer just rolled along (90F today)
Temps were all good, but I noticed my voltage which is set a 1.35 was at 1.28 when I was running prime95 not 10 seconds later I received a BSOD with the error code 124. (Also when I am not running prime95 and just a CPU intensive program like minecraft my Vcore is sitting around 1.31 and jumps to 1.34)
So I messed with some things and ended up setting my Vcore back to auto to see where that left me off at and low and behold when I booted up my Vcore was at 1.46V which is pretty high considering I should be able to hold 3.6 Ghz at 1.35v.
But my major problem is whenever I set the Vcore or not it will not give my CPU enough juice it just stays around 1.28V even though I have it set to 1.35V in the bios.
Any help would be appreciated thanks.
