9800GTX+'s are around $120 after rebate now, so that one is overpriced.
Originally Posted by dralb ![]() What is your budget? Also, any reason you are going to that site? http://www.newegg.com/Product/Produc...82E16814150316 |
Originally Posted by slickwilly ![]() Take a look at these they are all 9800GTX+ cards and under 160.00 http://www.newegg.com/Product/Produc...nd&Order=PRICE I would would pick the GTX over the gt for the extra stream processors and the GTX+ for the faster GPU speeds, scratch that I just took a look at your specs. your power supply would be stressed to run the GTX cards maybe you should upgrade your power supply first I wouold go with at least a 750-800 watt unit just so you would not have worry about your PSU. That is a great mother board you have but you will never be able to go SLI with it so if you want an Nvidia card you should get something like a GTX260 which are still dropping in price here are some Evga cards, Evga has tools for the OC enthusiast like Precision tool and voltage tuner that can make a vanilla card run like a FTW card http://www.newegg.com/Product/Produc...0781&name=EVGA Sorry I keep editing and making it longer, I was able to play Crysis at 1400X1050 @ high W/ 2X AA and get never drop below 60 FPS (I run V-sync on ) when I had a GTX 260GTX sc |
Originally Posted by darksideleader ![]() HD 4830: http://www.ibuildcomputer.com/cgi-bi...GAPEXSH&p_vlt= performs similarly with the 9800GT, better when AA is enabled and $40 cheaper. |
