1 - 6 of 6 Posts
ive been stress testing my overclock for a couple of hours. can i say that its stable if it pass the prime torture test(maximum heat one) 1024-128FFT?
A good indicator, yes...
Have you tried OCCT and Pi32 yo add to the confirmation
Usually 8+ hours is considered Prime stable. I personally run my PC's most demanding apps after running 30mins OCCT. If there's no crashes then I consider that stable.
Discussion Starter #4
where can i dl OCCT and Pi32?
if you can run prime for 8+ hours while browsing the internet and listening to music and such, then you're stable
1 - 6 of 6 Posts
