I seriously question the need for all this 24hr testing going on your brand new CPU, I see numerous cases here of guys bragging about their 24hr stress testing, or saying someones overclock is not stable because they haven't benched for 24 hrs.
A stress test is running all of your CPU cores flat out for however long you run the test, unless of course a core drops out because your overclock is unstable, I see the need for short term testing say an hour or maybe 2, because it won't take that long for an unstable overclock to show itself, but 24hrs in my opinion is not necessary.
There is not a thing on this planet designed to last forever, your precious CPU included when companies like Intel and AMD, guarantee their CPUs for 3 yr warranty time period, they're confident their CPUs will actually go past that time period, however that calculation is based on 3 yrs and beyond of normal use.
They know their CPUs are capable of lasting under normal spec'd use longer than the 3 yrs or they would not warranty them that long.
Now the cold hard fact is that overclocking your CPU will shorten its lifespan, but we accept that for the additional speed we gain, most of us will replace that cpu with an upgrade before is life expectancy arrives anyway, so taking it out of specifications is acceptable.
However that's with normal day to day use, surfing the web, audio and video editing and converting, gaming, office documentation Etc, and though serious bench stress testing is necessary to achieve a stable overclock, what damage does stress testing over a 24 hr time period and beyond, actually do to shorten the lifespan of your new CPU.
For example if you stress test your new quad core CPU for 24hrs, and all 4 cores are running at 100% for 24 hrs, how much normal daily processing is lost, because no daily application uses all 4 cores at 100% for 24hrs, so at least think about that when you overclock your CPU, and use at least some kind of wisdom in your stress testing.
Because if you don't think you're adding to shortening the life of your CPU, you're wrong!
All Credit given to Ryan from a different forum who helped me in my noob stages of Overclocking
