Impressive numbers, sitting here at 72ns+ with 3600 micron e-dieFor 2 CCD SKUs, 2 DPC SR configuration seems to be the way to go.
Both the 3600 and 3700X did 1800MHz UCLK on 1 DPC DR config, but most likely due to the discrepancy of the two CCDs in 3900X, it barely does 1733MHz on those DIMMs.
Meanwhile with 2 DPC SR config there is no issue in reaching 1866MHz FCLK/UCLK. That's pretty unfortunate since 8GB DIMMs cannot be considered as desireable or future proof as 16GB ones, due to the 32GB limitation.
Sure 16Gb ICs exist nowdays (hence allowing 16GB SR modules), but none of them can come even close to B-die in terms of frequency and timings.
Phy at AGESA defaults, except ProcODT of 40.0Ohm, which is an ASUS auto-rule for Optimem III.
tRDRDSCL & tWRWRSCL cannot be set < 4 CLK when the UCLK is operating at the limit, but that doesn't seem to affect the latency too much.
4 CLK already provides 100% efficiency for intra BankGroup accesses, but obviously it would ideally be set to 2 CLKs. Same goes for disabling GearDownMode, which seems to de-stabilize UCLK when it is operating close to the limit.
Increasing cLDO_VDDP seems beneficial > 3600MHz MEMCLKs, as increasing it seems to improve the margins and hence help with potential training issues. On previous gen. products it was only useful for shifting the MEMCLK holes, which were
present on certain CPU, motherboard and DIMM combinations. But then again, we never did this kind of MEMCLKs on those parts.
And before you ask. No.
Matisse version of RTC will never be public, sorry![]()
What kind of timings are they running at?Impressive numbers, sitting here at 72ns+ with 3600 micron e-dieContemplating if I should at this point just fork out the extra for some b-bie...
Surely you can improve the latency by tightening up tRFC and tRC for starters?
1900MHz FCLK/UCLK is really good.@The Stilt
Currently running Prime95 test to see stability of 1:1:1 2DPC-SR @ 3800Mhz with Micron E-die. with all stock voltages.
Looks Ok so far, only minor glitch was some mouse stutter/lag for a moment, but it went away when I put a load on the cpu. Will have too see if it comes back or whatnot.
I've found some buggy BIOS features that depending on which place you set the setting at you either get max 1800fclk/UCLK working(3600Mhz), but set it elsewhere in the BIOS enabled 1900fclk/uclk without issue(3800Mhz).
AMD CBS vs AMD OVERCLOCKING the later working better
I'm on a Gigabyte board.
Can't they do lower tRFC?If I knew what I was doing then perhaps, I've been relying on info from others since the calc is of little use for this setup.
Thanks for taking the time to offer pointers, I really appreciate it since I'm well out of my depth with understanding of timings.Can't they do lower tRFC?
tWR you should be able to lower, but I'm not sure if that makes any difference.
@Martin778For 2 CCD SKUs, 2 DPC SR configuration seems to be the way to go.
I'm surprised it even booted 1T with 2x16GB. I can run 3733 C16 2T any day but 1T, nope.
Any chance we may see some more presets find their way into ROG BIOS?For 2 CCD SKUs, 2 DPC SR configuration seems to be the way to go.
1DPC-SR on UEFI 2406/2501 is 60ohms for me. 1DPC-SR on UEFI 0068 is 40ohms for me. Regardless of which UEFI I use out of the 3, 3600MHz needs ProcODT 40 or fails for me.Also I've been hearing about ideal ProcODT for the new gen being between 30-40 now, Auto setting for me sets it to 60ohm which I have success with, would you anticipate any benefit to manually lowering it?
Interesting finds indeed. Does 0068 default to 30ohm or is it still 60 and your existing memory timings/settings wouldn't boot anymore?@The Stilt
3666MHz showed signs of lower ProODT aiding it, dunno if red herring yet. Below is all same setup, only ProODT changed in stages from 40 to 30.
My jaw was dropping, never got to OS, let alone to run RT on 2xxx with low end ProcODT.
Regardless of UEFI used and if ProODT is defaulting to 60 or 40, I do not get POST failure at 3600MHz, I encounter stability issue in Kahru RAM Test with incorrect ProcODT. All other settings for context are the same, only once ProcODT is 40 or defaulting to 40, Kahru RAM Test will pass high % for 3600MHz C15 1T GDMD.1DPC-SR on UEFI 2406/2501 is 60ohms for me. 1DPC-SR on UEFI 0068 is 40ohms for me. Regardless of which UEFI I use out of the 3, 3600MHz needs ProcODT 40 or fails for me.
Unless something very special emerges, then most likely not.Any chance we may see some more presets find their way into ROG BIOS?
cLDO_VDDM is not adjustable on any platform, at least for the time being, and I just added it to see if AMD uses any auto-rules for it.@The Stilt
Forgot to ask, I see in RTC cLDO_VDDM don't see this on C7H, will this be exposed on AGESA 1.0.0.3 or later on C7H? what is this voltage? cheers.
I found for voltage "spend" and next to nothing performance gain, when using say 3600C14/3666C14 I was better off at 3600C15, need 1.425V/1.455 vs say 1.355V.@The Stilt
Frankly I see no need for them, as the timings themselves make very little difference (compare to previous gen).
The performance is defined by FCLK and UCLK and the maximum frequency those will depend on several different things (CPU specimen, CPU topology i.e. 1 or 2 CCD, motherboard and the DIMMs, in terms of the configuration and most likely PCB type too).
Do you see any differences with +150 settings? I am on msi x570 ace and this settings does not do anything.I found for voltage "spend" and next to nothing performance gain, when using say 3600C14/3666C14 I was better off at 3600C15, need 1.425V/1.455 vs say 1.355V.
So far in testing nothing beats for performance/ease of gain "ability", PBO+150MHz 3600MHz using your 3466MHz timings, 1T GDMD. Simple set up of PBO, one step each on SOC/VDDG/VDIMM from default and nice gains in AIDA64, CB R15/R20, etc.
Thanks for the info as always.
When I target say 1933MHz FCLK board will not POST, not even with lowered RAM, have I hit CPU limitation, FW or god knows?
All the R5 3600/R7 2700X data in CB is from C7H, the other Ryzen CPUs are from C6H.Do you see any differences with +150 settings? I am on msi x570 ace and this settings does not do anything.
I use scalar x7 only.
My mobo sets the procOdt at 36,3 Ohms by default for 3600mhz.
