Status
Not open for further replies.
121 - 140 of 679 Posts
Same here. Initially preset was The Stilt 3466MHz timings, then other timings dropped lower.
Will be trying 3600MHz C14 on Zen 2 and moar once I finish other testing.
Arctic Silver 5, spread by strip of plastic card. I once tried Hydronaut, was so awful to spread, after that experienced I couldn't be bothered to try any other.
Same HW except CPU, room is ~24C R5 3600 screenie, ~22C R7 2700X, PBO+100MHz vs PE: Default PBO: Enabled, pretty much same RAM timings.
Best I had 3666MHz on 2700X was ~4000% in RT, got several ~3000% passes.
Wait, i missed what cpu cooler you are using. Temp is outstanding even without an undervolt. Must be a combo of spreading the paste, cooler, bios version/settings, chip driver, and silicon.
Dam, 1600 to 1800. My Flares should do as well. I have not crossed upon proof that 3200 to 3600 will make a significant lift in performance on the Ryzen 3000.
If there is no significant effect of going 3600MHz on the ram, then there is no reason to oc or there is no reason to buy expensive ram kits. Most reviewers are using 3200 CL16.
Meddling user
Custom WC, linked thread in sig OP has info :) .
3600MHz 1:1 MEMCLK:FCLK was too easy IMO. So regardless of gains I'd be trying that. SOC was measured on DMM when everything was stock, I saw ~1.010V IIRC, manually setting 1.025V matched that reading taken at defaults/auto. CLDO_VDDG stock is 0.950V, I bumped to 0.985V, VDIMM only needed to be 1.355V. So everything is so close to defaults I just would not be tempted to be a lower than 3600MHz ;) . I'd be tempted to tighten as much as I could from The Stilt's 3466MHz timings I have been using.
AFAIK 3200MHz C14 Samsung B die is highly regarded by The Stilt, so defo your in good place. I used 3600C15 4000C18 with the 2700X, as I gained nothing more than what I did with 3200C14 kit I sold those on.
Any how here is 3666MHz 1:1 MEMCLK:FCLK, after quite a day of rinse repeat I am happy with this profile.
I did upload whilst that screen video capture was going on. I stopped at 3K%.
I am now retesting with PBO+125MHz.
Voltage is still good. That's 3600X territory. You got skilz and that motherboard is showing its worth.
Hey i have 3200cl16 hynix m-die running on intel system. Do you think can i overclock it to 3600 c16 or c17 with ryzen 3000 ?
Does PBO overdrive work on R5 3600 with UEFI 2406 AEGSA 1.0.0.2, YES!
*** edit ***
Matisse Hypeship are coming to dock…
Gupsterg, quoting you in my article and btw good job. Due to review launch, I did not bother to test throughly PBO options but you've confirmed what AMD marketing has been saying. This could not be done on NPRP bios, as reported as TheStilt, me and other reviewers. Basically I said, PBO is broken or does nothing. I do not know if C7H has voltage reading points, but if it does, do you mind measuring idle and load voltages using PBO, greatly appreciate it. Good luck on your tests. With this new information I'll flashback F1 BIOS on Xtreme and see if I can make PBO work.
Computer Enthusiast
Thanks for sharing gupsterg. I've no idea when my cpu will be here but you're saving me (lots of us!) lots of time when it does arrive. Very frustrated I can't really contribute yet! Hopefully I'll get it by tomorrow...
Meddling user
Yes it verging on 3600X territory.
I'm sorry I have only used Samsung B die single side/ranked with Ryzen. Back in Mar 17 only then did I use some Crucial (Micron) & Corsair (Hynix) and they were lower end/speed kits. IIRC 2400MHz and they worked as they should, as at that time so much of the UEFI was lacking in options I really didn't tinker with it much. By the time more of the options came out I had sold that kit and moved to B die.
No problem, glad it was useful to you :) .
There are benchmarks in this post with PBO+75MHz.
Here is some additional info that you may find useful or not.
Within spoiler are some UEFI screens, the zip has what I use as base profile (ie stock) and the other has all settings for PBO+75MHz 3600MHz using :clock: The Stilt :clock: 3466MHz timings for Samsung B die. The OC txt only lacks the settings for PBO which the screenshot is detailing.
I reran RT this morning to get you DMM readings from the C7H Probeit points and power readings from wall plug meter. The power readings are for complete PC excluding screen. I should have perhaps set a fixed fan/pump profile, so do bare in mind power reading will be ever so slightly affected by that IMO.
Where CPU is stated stock I still had RAM OC'd to 3600MHz, SOC voltage is as it would be at UEFI defaults, CLDO_VDDG is 0.985V vs 0.950V of stock, VDIMM is set as 1.355V.
Stock: idle is ~0.920V steady, Kahru RAM Test loading CPU VCORE has swinging read, min ~1.302V to max ~1.360V, but it is more so closer to the 1.30V end than ~1.36.
PBO: idle is ~0.920V steady, Kahru RAM Test loading CPU VCORE has swinging read, min ~1.344V to max ~1.381V, but it is more so closer to the 1.344V end than ~1.381V.
Idle power reading is ~73-75W (slight swing) for stock & PBO. Under load stock is ~110W with swing upto ~120W, more so stays towards the ~110W side. Under load PBO is ~115W with swing upto ~125W, more so stays towards the ~115W side.
Below is RM for when on PBO+75MHz 3600S, red lined items do not match manual set values, EDC was 90A and SOC 1.025V.
Below is RM CPU stock but RAM 3600S, here only SOC voltage is out.
Below is RAM test runs screenies for this mornings readings of DMM/Watt meter.
Hope this helps and all the best Gup :thumb: .
NP :) , hope you get yours soon :) .
Hi The Stilt. Long time I don't see your Posts after you left Anandtech, had to stalk you a bit to find where you were posting.
I see that you're focusing on the CPU side of things. Do you have any data regarding Matisse IO chiplet? The IO die seems to hold a lot of secrets since it is supposed to be the same design than what is used for the X570 Chipset. Given than in Socket AM4 package and in Chipset package it offers two extremely different feature sets, I find it far more interesing than the CPU chiplet itself which shouldn't vary between Matisse, ThreadRipper and EPYC 7000.
Based on what we saw previously with Zeppelin, Socket AM4 pinout seems to be limited to how many features it can expose compared to what is really in the die. For example, Zeppelin in Socket AM4 package can expose only 24 PCIe Lanes and 4 USB, whereas in the single die EPYC Embedded 3200 series, it could do the full 32 PCIe Lanes + 4 USB. It also has a builtin 10G MACs, but AMD didn't said how it was multiplexed. Same happens with Raven Ridge, which in the Ryzen Embedded V1000 series seems to expose 6 USB whereas in AM4 only 4 (Albeit it has less PCIe Lanes), and it also has the 10G MACs.
Based on AMD slides about X570: https://hexus.net/tech/features/mainboard/131789-amd-ryzen-3000-supporting-x570-chipset-examined/
...Matisse IO chiplet seems to have at least 20 PCIe (In AM4 it exposes 24, 16 + 4 + 4), 12 USB, and 4 dedicated SATA. What I'm curious about, is the absolute maximum possible lane configuration (A la Intel Chipset Flex IO) that we could see in an EPYC Embedded product with a new pinout that exposes all what the IO chiplet is capable of.
I have recently been ranting about how I dislike Socket AM4 itself due to forcing you to use a Chipset, which in Zen generation is merely a glorified PCIe Switch with builtin SATA and USB Controllers, and how for mITX sized builds an embedded Zen counterpart actually makes more sense. Given the fact that Matisse IO chiplet seems to be wider than Zeppelin die IO, to me it makes sense for certain builds to kick out the Chipset from the platform and go full Zen 2 SoC. So far, there seems to be little interest in such products. I'm highly interesed on whenever you find such a product viable. I'm willing to sacrifice the upgradeable Socket just to expose more IO from the Processor package.
Meddling user
@FJSAMA
I wanna thank you for looking at my screenie shots and data closely :thumb: . I fully appreciate your private message pointing out the issue of CLDO_VDDP when I started using 3666MHz :thumb: .
@The Stilt
I had set a lot of voltages manually for my profiles as didn't want an [Auto] rule spiking something. I had left CLDO_VDDP: [Auto] as did not think an [Auto] rule would be present on it. It bounces to ~1.1V if left on [Auto] when I use just 3666MHz MEMCLK & FCLK, is this supposed happen? below 3600MHz it is ~0.900V.
RM system UEFI defaults/stock
RM system 3600MHz MEMCLK/FCLK
RM system 3666MHz MEMCLK/FCLK
RM system 3666MHz MEMCLK/FCLK manually set CLDO_VDDP.
Is also VDDP 1.05V on Matisse? on [Auto] 3666MHz profile I see 1.05V in ASUS Turbo V Core.
*** edit ***
Stock is 1.05V as well.
Discussion Starter · #131 · (Edited)
What is the IPC gain from Pinnacle Ridge to Matisse excluding AVX 256bit workloads?
Around 11.7%, if all workloads which receive any gains from 256-bit instructions are excluded.
But that is extremely hard to define clearly, without profiling each of the workloads.
Discussion Starter · #132 ·
@FJSAMA
@The Stilt
*** edit ***
VDDP != (not) cLDO_VDDP.
cLDO_VDDP defaults to 0.900V on Matisse and is sourced from VDDCR_SoC.
Because of that, the same rules that apply on cLDO_VDDG apply on it as well.
Meddling user
Thank you :) .
I have manually set:-
VDDP: 1.05V
cLDO_VDDP: 0.9V
And changing VDDCR_SoC & cLDO_VDDG as needed and keep to rule you posted before of allowing at least ~40mV gap between it and cLDO_VDDG.
The [Auto] rule for cLDO_VDDP slammed it to ~1.1V. Is this an oversight in UEFI in your opinion?
On 1xxx cLDO_VDDP was used to moved memory hole, I did tweak it on that. 2xxx I never played with it as did not encounter memory hole. What is guidance on it for 3xxx? have you seen any benefit of tweaking it?
Discussion Starter · #134 ·
Thank you :) .
It is based on AMDs guideline.
Unless you raise SoC to 1.15V or disable the load-line, you won't be getting much over 1.05V anyhow.
Meddling user
No not been there nor plan too.
Max I have gone to so far is 1.087V VDDCR_SOC and 1.047V cLDO_VDDG.
Glad inadvertently the Phy did not get that voltage.
Discussion Starter · #136 ·
Wanted to clear a common misconception people seem to have: The "Northbridge Frequency" displayed by CPU-Z is NOT the FCLK (fabric) frequency. Instead it is the frequency of the memory controller itself (UCLK). Normally both FCLK and UCLK operate at the same speed (MEMCLK). When FCLK and MEMCLK are desynchronised, UCLK will be set to 1/2 mode. Regardless if you lower or raise it below / above the MEMCLK. For example, if MEMCLK = 3200MHz and FCLK is anything else than 1600MHz, the UCLK frequency will be MEMCLK / 2 (i.e. 800MHz).
No third party software (for the time being) can monitor FCLK frequency.
Good to know. Mumak from HwInfo is talking to AmD if they can unlock to show the FCLK values in Third party apps. Would helpful for many users.
@gupsterg
NP. I didnt know if it was potentially dangerous or not, but hey, better be safe than sorry :thumb:
Reactions: gupsterg
Hi @The Stilt , not really what I found. First boot with a Ryzen 5 3600 in my C7H with Gskill flare x set to docp 3200 cl 14 the nb spped in cpuz read 1000, when I restarted znd set the fclk speed to 1600 it showed 1600 as nb speed in cpuz. Same as when set to 3600 mem speed and 1800 fclk speed.
Sent from my SM-G960F using Tapatalk
@gupsterg
Forgot I had my X370 C6H, updated BIOS to 7106 (AGESA 1002) AUTO OC + 200 MHz. Have not done any too much timings tightening and probably won't have time for the mean time (have to return chip). But anyways, was fun to meddle with. 3600 does seem to have more headroom.
P.S. Forgot C6H has the worst positioning for multimeter read points lulz
Status
