Struck me as odd and now ????
498 Views 6 Replies 6 Participants Last post by  redhat_ownage
I was looking at so ram articles and notice that in the picture the stick were in slot 1 and 3, in more then one picture. So heres why I think its odd because I have mine in slot 1 and 2 as the manual stats for dual channel slots 1 and 2 or 3 and 4(had to double check myself). So which way is the norm for dual channel?
1 - 7 of 7 Posts
They are usually color coded. And its usually slots 1+3 , and 2+4 for dual channel. IIRC
^^ Your right. That's the correct way for AM2+, AM3 boards afaik.
^^ Your also right, but that only applies to intel boards.
1 and 3 was for am2
Now all of am3 is 1 and 2...
Just the way they make it I guess.
Well thanks for clearing this up
ive had boards that the manual said duel channel works this way when in fact cpu-z and bandwith testing said it worked the other way
so the only way to know is to try both ways and check with cpu-z
whatever happened to the bios telling us when we run duel in the cmos post screen like on the a8n sli
1 - 7 of 7 Posts
