1 - 1 of 1 Posts
I spend a LOT of time thinking out my builds , this one over two months and wont be getting it for another week or two but heres my plan. I need criticism and feedback. To let you know prior to this,
A: I know a 360 rad is overkill for cpu only , plan on getting a gpu block when the 9000 series is released.
B: Will be using SP-120's on the rad
C: It was done in paint by a paint newb so take that into consideration
D: This will be w/ a xspc 360 kit, i jumped up for the d5 pump
E: I'm also an amd fanboy
1 - 1 of 1 Posts
