Hey guys. Been steadily fixing computers and it's been a while since I've been stumped. Unfortunately, this problem happens to be on my main machine and not a client's. (Xion in my sig).
I'll try to lay out some details of what's going on:
I came home from work and the computer had crashed. I use tracer RAM, and can always tell when it's a real crash and not just a video problem, as the lights on the RAM will freeze.
OS is of course corrupted now and will not boot. Not worried about that for now. Can always format when I find what is going on here...
I went through a long series of tests and as I approached my wit's end...well the system's now benched. I have a PSU, CPU, PS/2 keyboard, DVD player, and on board HDMI cable installed.
I use 4 sticks of RAM, and testing each one independently, they all check out fine in memtest. I can use different slots for the one stick of RAM and checks out fine, I post, I can boot into a windows disc, etc.
As soon as I add my second stick of RAM, it crashes. It may run for 10 minutes, it may run for 20 seconds, or it may not post at all. Some interesting things I noted while 2 sticks installed...odd behavior:
-The machine will power on but no post. If I use tracer ram, the ram is dead in the water, no activity.
-CPU fans, any system fans I plug into the motherboard, DVD drive will all be powered.
-No post beep codes at all.
-During this freeze, it is common (but not always...) for me to be unable to turn the system off without disconnecting power. I'm using the diagnostic power switch on the board itself at this point to rule out the case switch, wiring, etc, and holding it down does not shut off the fans.
-Disconnecting power and reconnecting it (with a PSU switch from off to on in between) will cause the machine to fire up by itself. SOMETIMES. Sometimes it does a full power on back to the freezing, no post crash. But sometimes the machine powers on all fans for just a second or two, and then powers off again. I believe this could be a normal part of the process with the power supply, to power on after a power failure. Funny thing about that is- the setting in the bios for it is set to NOT power the machine back on. (PWR OFF)
-Sometimes I can post with two sticks installed, and run some memtest, where it goes back to the freeze and won't shut off.
-I have tried leaving all settings stock and auto, letting the board decide on RAM voltage (which is lower than crucial recommends) and timings, cpu clocks, etc. Same result.
-I have tried my go-to stable sally settings that have always reliably worked for years, which is the following:
3.2 GHz clock @1.35V
NB to 2200
RAM 4-4-4-12 @400mhz (800 real time) +230mv to bring it to 2.0V (if I remember correctly...it's what crucial recommends and how my weirdo board achieves 2.0V on the DIMMS, I just always remember +230 since it's what I set)
And same results.
-I have tried upping the voltage a little bit on both my NB and CPU within safe parameters just to see if maybe my chip was getting old and maybe required a little more juice.
Same results.
For a reason I cannot explain, this computer that has given me so much love just refuses more than 1 stick of RAM out of the blue.
Obviously, this is ruled out to (correct me if I'm wrong please) one of the following:
-Motherboard has gone to crap. This is my highest suspicion, as I have already run into problems with this board on a cold boot. Narrowed this down to a capacitor issue on the board that goes away once the computer runs for a minute. But this is a flaw that has been with this board and I's friendship together for a long time and has never caused any issues.
-CPU has turned into garbage. More specifically, possibly the memory controller. Is this not a rare occurrence? What are the odds this lightly run 955BE is bad now?
-PSU is pooped. This is a really nice and fairly new PSU guys, and I just REFUSE to believe that this is a psu issue, especially not being a power load trigger but a RAM trigger. It is however something I haven't switched out. Main reason being, to do this I wouldn't be typing on this machine right now...and my wife would cut me.
-My computer is haunted.
Seriously what in the actual heck is going on here? What would you try to at least figure out what parts to order for sure? I don't want to order an outdated replacement mobo just to find out it's the cpu. I don't want to order an outdated cpu just to find out it's the ram slots. There's gotta be a test I'm missing here.
Help. Other than trying to reseat the cpu, I'm pretty much out of ideas.
Cheers peers!
NB to 2200
And same results.
Same results.
Cheers peers!
