1 - 16 of 16 Posts
Ok.. like I said.. Im a newb so feel free to make fun of me.. Anyway, Im attemping to overclock.. Ive gotten from 2.4 (stock) to 2.615 stable by bumping up the FSB from 200 to 218. I cant seem to get anything stable past that though.. Ive tried lowering the mem clock and upping the FSB and that allowed me to get to 2.7 but it wasnt stable.. any help is appreciated. thanks. Here is a screenshot BTW..
Lets try 2.8 right out of the gate....
234 x 12
HTT (LDT/FSB) multi x4
Vcore 1.5
Memory voltage 2.7
memory timings, default
memory divider 1:1 200 (400)
Discussion Starter #4
ok.. how do I set the divider?? Is that were it has the differnt listings for mem speeds? like 200, 166, ect? There isnt anything in the BIOS that says divider I dont think.. Im using Pheonix 6.00PG if that helps any.
yes, max memclock. Thats the divider for your memory. We want it running right with the FSB 1:1 so set it at 400.
If you can, post a link to your memory on newegg, or wherever you bought it..I want to look at the specifications
alright cool, you might want to change your timings to 2.5-3-3-6 1T. Forget about the tighter timings, you want bandwidth!!
I have the exact some processor, i J ust bought it and I got to 2.82 just fine, on stock cooler.
I just upped the fsb to 225 i think, maybe 235...
Discussion Starter #12
man.. I cant even get to 2.7 stable without having to bump up the vcore to 1.5v I dont know if Im doing something wrong or what..
Discussion Starter #13
my BIOS is werid.. it adjusts vcore by percentages.. I set it to the highest setting which is 1.5v.. well it jumps around from 1.488 to 1.520
1.5 isn't high vcore. Actually I would expect it to take 1.5-1.6 for 2.7. If your vcore maxes out around 1.55. I would leave it at that, and see how high you can get. 1.55 is not harmful at all.
1 - 16 of 16 Posts
