Originally Posted by OmniAngel will a intel processor work on an AMD mobo? |
Originally Posted by Allen Naaa man sory i wont but i think the AMD is better any way but thats just my opin. mabe you can sell the intel and get a AMD or sell the board and get a intell one ![]() EDIT: what kind of AMD is it XP or 64. |
Originally Posted by SpookedJunglist Yes it is possible ![]() But i would recomend against it. ECS made a board that takes both LGA775 and s939 CPUs via a daughterboard that contains its own memory slots. The motherboard is feature rich but from what i have read the intel chips seem to work about average compared to other motherboards but the AMD side seems to be lacking wall below the rest of the pack. It might be possible for this to be fixed in the future via bios/firmware update. I still think it is a bad idea but here is a picture showing it with the daughterboard atached I think that the fact that they did it earns ECS a lot of credit in making the effort to create a dual platform motherboard. Maybe they will figure out how to make it work propperly. And who is to say that in the future as technology stays the same for your southbridge and its components[PCI-E, Sound, Ethernet, USB , SATA, And PATA]. Maybe they will sell a base board that holds all those components and you can upgrade your daughterboard to new TECH. Saving you the time it takes to remove your motherboard and all your drives just to upgrade. Wow that is a really good idea. Think about it you want that new CPU that came out. You buy the cpu and the daughterboard and install it if you want to switch back you just swap the CPU slot. Pretty cool stuff linkage |
