1 - 20 of 36 Posts
Just woke up and found that Windows decided to install updates and restart itself. The strange thing is that when I first installed Windows 7 I told it never to download or update without my permission, and I just checked and it was set back to automatic updates again.
Arg! I just lost 8 hours from my bigadv unit, I was at 30k PPD and 72k credits. I'm sure that'll go way down now.
Yeah, happened to me last Foldathon; set it not to update, then it updated anyway.
Oh well, hopefully no issues this month.
Man with Fans
Screw the updates.
When I setup my computers, I don't even turn on updates.
They're turned off right from the start.
Windows can nag all it wants, I don't care.
Same thing happened to me. Windows usually gives the warning on when it's going to automatically do it but I never saw it and I always fold all night but when I came back to my computer this morning I had to sign back in. It should at least RELAUNCH the applications you were running.
Originally Posted by DaMirrorLink View Post
make [email protected] start with windows? o_O
thats how mine is
I didn't have WIidows set to log in automatically.
Originally Posted by Volvo View Post
Screw the updates.
I think it's more the fact he turned off Automatic Updates, but they still installed.
ah yes smp
and he doesnt know how to read, sadly
Discussion Starter #8
I can set SMP to startup automatically when Windows starts I guess. Will it startup even if I haven't put in my password at the Windows login screen yet?
If not, how can I do that?
Essential Threads> Automated Folding.
Also in red text in the OP of the Foldathon.
do you have any system maintenance software like Tune Up Utilities installed ?? coz those programs usually tend to set Windows Update to automatically install update.
I disable updates, tell windows to auto-login, and then have the shotcuts in the startup folder
Discussion Starter #12
I updated my anti-virus and it asked me to restart my machine, and I told it no. Other than that I can't think of any reason why it'd revert back.
I am not getting caught by Windows updates anymore but with my watercooled rigs not having a cpu fan plugged in will stop the boot process. I have gotten around it by simply having a fan plugged in but I have been told I should be able through BIOS to remove the parameter that stops the boot proces when no cpu fan is detected,not found as of yet.I am using ASUS boards and the cooresponding BIOS.
Not new to Overclock.net
my i7 computer did an update last night... restarted itself, but got hung on startup because I did not have a keyboard plugged in
Normally it should start up and resume folding
Discussion Starter #15
Sounds like a few of us all had updates go through last night. Did you have yours set to automatically update?
no.
It was a forced update. There was a notice that popped up on my computers saying that it would install.
I installed the updates on 3 of my computers, but I must have forgot to do it on the i7 computer.
Originally Posted by dontknowa View Post
I actually manually updated my window, restarted, and continued my folding
Right. It gave the warning for you to manually update, or else it would do it for you
Discussion Starter #19
no.
I'd have been ok with that, if it didn't happen at 2am while I was asleep.
this whole issue can be resolved with a registry tweek. Who's computer is it anyways.. yours or Microsofts.
Run Regedit.
browse to HKEY_LOCAL_MACHINE\\SOFTWARE\\POLICIES\\MICROSOFT\ \Windows
Right click on Windows, and select "New" then "Key"
Name the new Key "Windows Update"
Now create a new key under Windows Update, and call it "AU"
Create a DWORD value for AU, and call it "NoAutoRebootWithLoggedOnUsers"
Right click this DWORD, select Modify, and give it a value of 1.
After you reboot your computer, you will no longer ever face restarts that you don't initialize.
1 - 20 of 36 Posts
