So i posted this in HTPC section and only got one reply after 24hrs.. so i thought id try here
So i traded my old gtx 460 for a HD 7770 Ghz edition (sapphire), whenever using the GUI in XBMC It gets slight stuttering. This is my first non nvidia card and im quite annoyed...
i did drive sweeper and installed current drivers for the 7770. should i un-install then re-install XBMC? OS is Window 7 home premium 64 bit. or is there something in settings ive missed?
movies music etc run smooth till GUI (menu) is used?? cpu is e8400
EDIT i have uninstalled XBMC and reinstalled it. still have the problem,. could it be anything to do with nvidia cude? its only since ive changed the gpu.
