1 - 13 of 13 Posts
Hi there.
I have a weird stuttering issue with multiple monitors. It feels like a simple loss of FPS on the desktop. When dragging windows around it will start to stutter then go smooth again. It will continue to do this for as long as I drag things around. Starting off smooth for a couple seconds, then stutter for a while then smooth again.
It's really annoying when moving windows from monitor to monitor and even when scolling on a webpage (i use smooth scrolling.)
Anyone have a similar issue and have a fix?
I'm NOT new to Overclock
Sounds like its your Idle speeds or something...
Can you increase the idle speed of your GPU? I think MSI afterburner can do it.
what are the settings on both of your monitors? they need to be exactly the same if you are having this problem ie my sig
Both exactly the same monitor with same settings as far as I know. The stuttering is not awful but just wondering why it's doing this as my brother is running 2 monitors on a GT240 and runs smooth and mine don't on a GTX260
make sure you check the refresh rate, if they are the same, then try comps idea
Discussion Starter · #6 ·
Upped it quite a bit and still seems to be there.
Yeah checked the refresh rate. Both at 60.
This is going to sound stupid,
Can you run kombuster, whilst running that, then drag the windows. lol I know it sounds stupid but jsut see if they still jump.
Cheers
Comps
Discussion Starter · #8 ·
Yeha no problem, i'll try that now and get back to you
EDIT, yep still does it. :/
In which case, not sure.
Does it happen when you're running stock?
Well, it has only started doing it today and don't really want to go all the way back to stock as i don't think that is the answer. I also got a new mouse and not the best drivers I have ever used so i'm going to investigate that aswell. (Roccat Kone)
Discussion Starter · #11 ·
Scratch that, still have the issue.
Discussion Starter · #12 ·
Bump, still doing it. Anymore Ideas?
Discussion Starter · #13 ·
Bump
1 - 13 of 13 Posts
