There's always the 120gb ipods... 6th gen I believe.
Originally Posted by DuckieHo ![]() Are they SATA? I'm searching eBay and see most have Zero Insertion Force connector... is there a SATA plug underneath? |
Originally Posted by trueg50 ![]() Ebay link, $125. *Note this uses the micro-SATA connector* Though this cable should work. Very tricky to find, I had to use this Toshiba model number: "MK8016GSG". What will this be used for? I have used 1.8" HDD's in the past, and the performance is just horrid, but knowing you you already know that, and this is for a low power/small space computer. |
Originally Posted by DuckieHo It's just for a movie storage. As long as it can do 20MB/s read and 12MB/s write, I'm fine. |
One nice thing is that installing the hard disk drive is optional. If you don’t want to add one, you can play back media through a connected USB storage device or from the Internet via the built-in 10/100 LAN connection. You can also hook the Box Office up wirelessly, but to do so, you have to purchase any optional Patriot USB 802.11g Wi-Fi adapter. |
The biggest downside to the Patriot we had, however, was its loud fan. Now, I say loud, because in my home theater environment it was the loudest piece of equipment I had. Even from 12 feet away where we sit to watch TV, I could hear the Box Office turn on and off. The effect was even more pronounced when we moved the box to a bedroom. We told Patriot about the loud fan and they informed us that we must have a defective fan as it is rated at just 20 dBA. Our sound meter was showing 52 dBA from about a foot away from the unit, so something obviously wasn't right. Patriot expedited a new unit to us and when we turned it on, it was like night and day. The sound from the new box was much quieter than the pre-production unit that we originally recieved. |
Originally Posted by trueg50 ![]() From Hardware Secrets review: So couldn't you use a 2.5" HDD in a 2.5" enclosure and keep that on top or behind that media box? In the Legit reviews review of it they had a similar encounter, but it proved to be a pre-production model glitch: . Seeing as how Hardware Secrets had a similar pre-production unit, it could also have the same problem. |
Originally Posted by DuckieHo ![]() http://www.hardwarebook.info/ATA_ZIF It looks like it's ATA ZIF and not SATA ZIF? |
