Photos to help
No not original I bought this in first photo didn't work then ordered that in second photo stoll nothingJust for clarification, do you have the power cable for the sub?
Yeah I wanted a new one but my boyfriend wanted to use this cause it was free. Thanks for your helpYou won't get that sub to work, unless you have that cable / special box.
As far as your AVR, you also don't have pre-out sub.
So you're pretty much left with getting a new sub that has high power inputs (speaker cables).
On the positive side of things, any entry level, cheap subwoofer will sound better.
View attachment 2558765Bose Lifestyle 25 Series II Owner's Manual (Page 12 of 42) | ManualsLib
www.manualslib.com
I didn't have coffee yet... yes I have power cable but not other cablesJust for clarification, do you have the power cable for the sub?
It was probably free because there is no practical way to use it without the speaker kit it came with. It's junk.Yeah I wanted a new one but my boyfriend wanted to use this cause it was free. Thanks for your help
This.. That subwoofer is designed to be used with a specific set of speakers, and basically uses proprietary ports.It was probably free because there is no practical way to use it without the speaker kit it came with. It's junk.
If you want a cheap subwoofer go to a thrift store.
