1 - 11 of 11 Posts
Ey All
So i find myself going to be using my camera alot more.
But currently none of my bags really do fit both my 13" laptop and DSLR well with room to spare. So I carry around a big duffle bag with everything to cut down on septate bags. Anyone happen to know any good light backpacks or messenger bags that are designed for both?
- Well Built
- Under 100
- Configurable Dividers would be great
- DSLR Body + Space for len(s)
- 13" Laptop + Small Charger
· Premium Member
For under 100? That's kind of a stretch I would imagine, if you want a quality bag to use as a messenger/camera I would check out a Timbuk2, Chrome or Incase. You can always get a camera insert (I believe Domke makes them) to fit inside a regular messenger bag as well.
· Premium Member
i have a lowepro fastpack 350 which i bought for like 80 bucks a few years ago which fits my a900 (non gripped) + 70-200, 24-70, 85/1.4, 17-35, a flash and my 15" xps. only problem is there is no real tripod holder on the bag.
Got my Veloce V in bungee cord on Tuesday and I love it. It's not the biggest; but it holds my camera, 3 lenses, an air blower, and even a compact tripod.
My 055xprob won't fit inside of course, but it will strap to the outside.
It's stylish and comfortable as well
Edit: Forgot some of the bad points. Most of the dividers move, but not all of them. Materials aren't the greatest, but I'm also kinda picky. It's also not quick to access because the straps often get in the way of the zipper. All in all, I'm still very happy.
· Premium Member
Originally Posted by cookiesowns View Post
Any recommendations for bags that can fit 1 body and 2-3 lenses? As well as being able to fit a 15 inch thin laptop.
http://goincase.com/products/detail/dslr-pro-sling-pack-cl58060
I use this bag for taking a bunch of gear and a laptop, but also own the smaller sling for bringing my Surface, X100 and assorted other stuff on a daily basis. Incase bags are great, the Ari bag is my favorite -- but I can't buy one because one of my buddies has one already. Ahhh, vanity.
1 - 11 of 11 Posts
