Ok so this is my Casehttp://www.newegg.com/Product/Product.aspx?Item=N82E16811119194&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Cases+(Computer+Cases+-+ATX+Form)-_-Cooler+Master-_-11119194
i want to move the PSU from the bottom of the case to the top, like literally on top. i would like to create something like an extended bay type thing.
i plan on using either plexi glass and then do some designing on it or just fitting some steel sheet metal up there and solder (weld if i can).
i also have a 240mm rad to put up there. (if not possible i may be able to mod something on the bottom as well to take the fit)
does anyone have any suggestions?
im all ears.
im all ears.
