1 - 14 of 14 Posts
I'm trying to get my Sandy stable over 3.0. Ideas?<br><a href="http://assets.overclock.net.s3.amazonaws.com/9/9e/9e90abd2_vbattach34356.jpeg"><img src="http://www.overclock.net/image/id/616174/width/525/height/525/flags/LL"></a>
What divider you use 100 in bios or 166?You can use overvolt's.
You don't have the overvolt option in your Bios?
try up volting your CPU because your temps are very good, and you can definately go alot higher. Also, you may want to try playing with your multipliers if your memory can handle it.
Or go lower divider and go for the max fbs OC.
Reactions: Firefly
lower your multi to 10x and raise your HTT to 300. Then run the 133 divider. if you put 1.55v to it, it should go fine. it took 1.55 for my fx-55 sandy to hit 3 ghz. my core temps was up there a little bit, around 55-58c but CPU temps were fine. was running it on a venus12 heatsink...piece of crap
Discussion Starter #9
<tr>
<div>
Originally Posted by <strong>mudd</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1394451#post1394451" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">lower your multi to 10x and raise your HTT to 300. Then run the 133 divider. if you put 1.55v to it, it should go fine. it took 1.55 for my fx-55 sandy to hit 3 ghz. my core temps was up there a little bit, around 55-58c but CPU temps were fine. was running it on a venus12 heatsink...piece of crap</div>
</td>
</tr>
</table>
</div>The problem is that my MoBo maxes at 292<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
well is there an option for 300? if so, crank up your northbridge voltage a bit, jack up your memory voltage and run 2t timings. see what happens.
Discussion Starter #12
<tr>
<div>
Originally Posted by <strong>boredom</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1394494#post1394494" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Why are you running your RAM at 2t and 208mhz?</div>
</td>
</tr>
</table>
</div>Yes , T1 does not work very well.
<tr>
<div>
Originally Posted by <strong>Firefly</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1394567#post1394567" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Yes , T1 does not work very well.</div>
</td>
</tr>
</table>
</div>Are you running 3 or 4 sticks of RAM?
<tr>
<div>
Originally Posted by <strong>gonX</strong>
<a href="showthread.php?s=f0ff622456a527c34b14aeab359ee59d&p=1394571#post1394571" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Are you running 3 or 4 sticks of RAM?</div>
</td>
</tr>
</table>
</div>Memory<br />
OCZ gold 2gig<br />
<br />
i take it he's running an OCZ kit.<br />
<br />
you might need to see if there's any "special" faqs for your motherboard. i know that in my old MSI Neo2 board you had to have your memory in specific slots in order to run 1t.
1 - 14 of 14 Posts
