sunbeam pci bracket wiring
988 Views 2 Replies 2 Participants Last post by  Nick911
Attachment 131213
I had to solder the wires but now the controller doesn't control the fan speed any more. How do I wire this correctly?
black and red went into the mobo, off the red and black is the 2 gray wires that connect to the fan.
Is the yellow wire what controls the voltage? I would think so considering that taking 2 wires to mobo and then from mobo would completely bypass the fan controller since electricity goes were it wants to.
1 - 3 of 3 Posts
Can't tell what you're trying to do from that picture. Perhaps you could give a model number or a picture of the wiring instructions from the manual, and also tell what you are trying to do.
The yellow wire is the "speed sensor" wire. Every time a fan (3 wire, red/black/yellow) rotates it sends a signal through the yellow wire. The fan controller counts those signals (one signal per revolution) to determine how fast the fan is going.
I have no picture or manual, if I did, I wouldn't be having a issue. I'm trying to control the fan speed from 0 to 12 volts. Thing is the controller isn't wired correctly. I thought how I wired it and explain how I did it was going to work, seems it did not.
1 - 3 of 3 Posts
