1 - 17 of 17 Posts
Music Producer
Wanted to do this for shiggles, I basically put it on my heatsink with masking tape lol. My temps were higher by 4c on idle and 8c higher on load. haha. I took it off after and put back my normal 92mm fan on.
Music Producer
Originally Posted by ghettogeddy View Post
do you have a case fan in the rear
I'm confused, what?
the picture is too blurry and bright......I don't see what you did
That's what she said
There are two giant fans inside that barely cover the heatsink.
Super Moderator
So you installed a push / pull and got worse temps? You did it wrong then.
Music Producer
Discussion Starter #9
My heatsink is only supposed to use 92mm fans, lol. And yes there is a rear exhaust fan, I don't see how you can't see it. lol
i dont know how to ask that more clear lol.
lets try
is there a fan on the rear of the case
is there a fan on the back of the case
is there a fan where one belongs on the back of the case
omg what case is that it looks bigger than my haf 932
as for the tape and fans... maybe you should have taped a couple of delta fans on it ... more flow more cooling !!!!
His sig says;
CHIEFTEC BRAVO BA-01B-B-B Black Steel Full Tower
And yes, it is bigger than your HAF 932. In fact, many cases are bigger
Originally Posted by EditeD View Post
His sig says;
bigger than my HAF?!!!!
no way!
well my next case is going to be a full size server case
and to keep this thread legit... i will use some tape to keep my fans in place
no way!
id say its about 120mm+ larger then your haf lol and cheaper
anyways i dont see a rear exhaust fan i see the big side one witch is prolly killing air flow i see what looks to be a 80mm done by the gpu maybe lower
then the 2 large fans on your 92mm heat sink
the yellow circle looks like a lil light is there but i cant see a fan lol
Music Producer
Discussion Starter #15
Without the side panel 120mm fan my airflow is incredibly bad. I took more pics so you can understand how airflow works in my case. Ive taken incense and lit it to see where the smoke goes and this is exactly how it works. The arrows that point below the cathode on the bottom get channeled to my PSU to help cool it more efficiently.
Exhaust 120mm fan:
Retired Reviewer
If you get two fans too close to each other, one will interfere with the other. That is why ghettogeddy asked if you had a rear exhaust fan. Since you do, we know why your temps went up.
Remove that rear exhaust fan and try again. Better: remove the fan and the grill behind it. The your pull fan will act as a case exhaust. See item 2. in my sig.
Music Producer
Discussion Starter #17
lolk
1 - 17 of 17 Posts
