1 - 20 of 21 Posts
Package of the cooler:
paketti.jpg?t=1267381412
Accessories:
sislt.jpg?t=1267381449
Cooler itself:
cooleri.jpg?t=1267381432
Base of the cooler:
08012011957.jpg?t=1294675914
Installation:
Same as Corator DS. Sry, no picture.. 
Cooler installed on test system:
Taken different time, but there it is!
noctuaspecs.png?t=1294676226
Test system:
AMD Phenom II X6 1090T BE (stock & overclocked 4,2GHz 1.45v)
Asus Crosshair IV Formula
Corsair Dominator GT (1600MHz 6-6-6-18 1T)
Corsair HX1000W
Samsung F1 750Gb
Samsung DVD-RW USB2
Dimastech Bench/Test Table Hard V2.5 Inox
BenQ G2411HD
Windows 7
GeForce GTX 580
Testing method:
I stressed CPU 15 minutes Prime95 largest FTT-size with every cooler and watched temps from HWMonitor-software.
After stress I led CPU idle 10 minutes and watched temps from software mentioned before.
I tested every cooler with CPU's stock clocks and overclocked to 4,2GHz 1.45v NB 2,8GHz 1.35.
I also tested every cooler with Xigmatec XFL-1253-fan(s) and overclocked CPU so results would be fair and I could see the real "power" of these coolers.
Cause Prolimatech Super Mega doesn't include cooler, I used same Xigmatec XLF-1253-fan with it.
Ambient temps were 25,4-26,2°C while i tested so delta-values wont be needed.
Results:
Stock
Lmmtvakioenglanti.png?t=1294678143
Overclocked
Lmmtylikellotenglanti.png?t=1294678240
Xigmatec XLF-1253-fan(s)
LmmtXigmatecenglanti.png?t=1294678227
Plus & Minuses
Corator DS (EDITOR's CHOICE)
+Price
+Installation
+Cooling
+Fan
-Support for only one fan
Noctua NH-D14
+Cooling
+Installation
-Price
+Cooling
+Look
-Price
-No AMD mounting included on package
-No fan included on package
Thermalright Silver Arrow
+Cooling
+Quitness
-Cooling with stock fans
-Installation
Thermalright Venomous X RT
+Cooling
-Cooling for it's price
-Price
-Installation
Discussion Starter · #8 ·
Test system:
Intel i7 2600K (overclocked 5GHz 1.48v, HT on)
Asus P8P67 Deluxe
Corsair Dominator GT (1866MHz 8-8-8-24 1T)
Corsair HX1000W
Samsung F1 750Gb
Samsung DVD-RW USB2
BenQ G2411HD
Windows 7
GeForce GTX 580
Testing method:
I stressed CPU with IntelBurnTest 15 rounds High-setting and 8 threads (HT on) with every cooler and watched temps from RealTemp-software.
I tested every cooler with Nanoxia FX12-2000-fans, expect Coolink Corator DS which wont support more than one fan.
Result:
it's not more secure, just more comfortable...
for those who don't know:
Noctua= Rascom (Austria) + Coolink (Taiwan)
Rascom is basically responsible for Marketing, Design, Service, Ideas, while Coolink devolopes and produces the actual Heatsinks
Thatz's why they have the same mounting system
AS far as you temperatures go, i tested the super mega, D14 and the SilverArrow on a [email protected], and it was SA>D14>SM; all within 3°C though (with the same fans
Retired Reviewer
Did you use 140mm fans? Since OP used 120mm fans on all the heatsinks, that might make a difference. But note they were all close to each other.
Well, I think this proves that modern top air coolers are all pretty much hair splits of one another, depending on chip used, fan, ambient temperature, position of sun and moon....
Regardless who "wins", we should all agree that sub-50 temps, on a heavily overclock hexa-core, on air, is nothing short of amazing. Unthinkable even five years ago.
Make me wish these things existed back during the Netburst era
Do you have a link ?
No drama I found an interview.
Also more comfortable, what you wear them as a hat?...lol.
i did use 2x120mm silent Wings Pure 1300rpm fans and 2xTY140s
once at 100% and once at 50% fan speed , with 50% it was D14>SM>SA though....
1 - 20 of 21 Posts
