I just ordered this board for my new budget 2500K build. IMO it seems to offer the best mix of features, performance, and cost among budget socket 1155 motherboards. I have read that some people are having issues with overclocking using manual settings with this motherboard, but it doesn't appear to be a widespread problem. Hopefully ASRock can fix the issues these people are having with a new UEFI update.
Also, for those of you that worry about the board limiting your OC a fellow member on here (
bigmac11) had this result with his board (extreme 4, basically an extreme 3 with more features):
http://valid.canardpc.com/show_oc.php?id=2011732
Not bad for a board that costs about half as much as more mainstream/popular boards.
Edit: My total came out to $114.99. That's cheaper then my current budget motherboard cost 3 years ago.
