1 - 8 of 8 Posts
Good day!
I currently own a 550watt HEC Win Power PSU. I got it three years ago when I assembled my core2quad build. Its not 80 plus rated or anything but it has powered my 8800GT before all up to my current specs with no problems.
I am planning to buy a new mid range graphics card possibly in the new range of graphics cards from Nvidia that is rumored to come out possibly this year. If those are too expensive maybe I will get a 560 by the time price lowers because of the new releases.
I am not so sure if I have to get a better power supply to prepare for that. I am actually not even sure if the HEC Win Power can support a 560.
The psu I have supposedly is "SLI ready" as what the box says. I don't know the truth in that as I have not used SLI before. I understand though that the 560 and other boards have two 6-pin power connectors required. The psu I have indeed has two 6-pin connectors but they are on the same cable. That adds to my worry since I am not sure if that one cable with two 6-pin connectors can power a single card. Some people have said it is OK to use one cable for the two 6-pin power connections required for a single card.
I have posted this same question as an add-on to some of my other threads but not as a main concern as I am doing now. Some people have advised me that I don't need a new psu yet and my psu can power a 560. But I am not sure if they are aware that this is not a brand new Win Power. Maybe they are referring to a new release of the same Win Power series from HEC - I don't really know.
So I am looking for expert advice if I need to buy a new psu or not. I am hoping I don't have to buy a psu yet since a rated psu is so expensive. I would also like to understand how to compute and estimate for psu requirements.
Thank you!
That's not a good PSU at all, but you won't stress it in any way.. you should be fine.
This reply is exactly why I got confused.
That is scientifically impossible as your confusion predates my reply..
Discussion Starter · #6 ·
well not that literally. Your reply has some conflict to it. You say it is not a good psu but you also say it should be fine. I have read replies like this before, and I know that the psu I have is not a top notch psu. That's the reason why I said I am confused and the reason why I opened this thread.
Please give me an explanation as to why my psu should be fine even though it is a bad psu.
Originally Posted by selectstriker2 View Post
Personally I would not use that PSU. If you are looking at a new one I'd look at one from the Antec High Current Gamer series like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16817371048 . A good 550W+ unit will be able to support a newer card.
I doubt I will find that same antec 620 for the same price from where I come from. Almost everything is overpriced here from retailers.
I was hoping I can gather enough money to afford a semi-modular psu.
Anyway please provide me some details as to why my current psu cannot provide enough power and how does this new psu you recommended can provide it.
i hope it will not be too mathematical though. Just give me concepts for me to understand.
It's an old, Passive PFC trashy PSU with a low 12v rating.. but your system with an added GTX 560 will max out to about 300W, and the unit should be able to handle that(for a while at least).
If you can buy a new PSU you should obviously do it.. in which case you should link the shop/s you'll be buying from and your budget in the local currency, this way you'll get the best suggestions.
1 - 8 of 8 Posts
