SuperPi is used to messure the time taken of Pi calculations which are used when overclocking.
It is widely used to see the performance gains of overclocking as the times of a 1m calculation are recorded at stock values and at overclocked values.
In theory they do test whether the chip is stable but only with 32m calculation which is very intensive on the CPU.
If you want to check whether the components of the PC are stable you can use Prime95
