I bought a 5.1 system and i dont know how it works, after i installed it i tried to do the Windows test and only the speakers worked so i thought i had drivers problems after hours of searching updates i rolled the drivers back and then updated them using the search online option.
Now i do the test and it works but i go to youtube and use some test videos and they dont work, only the front speakers are working. when i listen to a song i can only hear the front speakers and the subwoofer. My sound card is the SupremeFX X-Fi that came with my Rampage II Extreme. the software that came with it expired and i cant find a keygen to make it work.
