1 - 20 of 72 Posts
<b>Declaration of Interest:</b> I have purchased these cards myself from a reputable UK computer e-tailer; none of this hardware or software has been donated or loaned for the purposes of this review. There are therefore no conflicts of interest which could arise which would bias this review in any manner.<br><br><div style="text-align:center;"><span style="font-size:x-large;"><b>Surround Gaming with nVidia GTX460 Graphics Cards: Is "The Mainstream" Card Good Enough for Gaming at Ultra-High Resolutions?</b></span><br><br><i>Author: Paradigm Shifter</i><br><br><a href="http://www.overclock.net" target="_blank">www.overclock.net</a></div>
<br>
Right, let's cut to the chase.<br><br>
Surround resolution testing.<br><br>
nVidia Surround is the nVidia equivalent to ATis EyeFinity technology, which in turn was their version of Matroxes TripleHead2Go unit. With the release of the GF104, affordable, capable nVidia Surround is within the grasp of those who, for whatever reason, do not wish to purchase used GTX200 series hardware or a GTX470/480.<br><br>
When I originally bought two GTX460 1GB cards to run Surround, I was amazed at the performance available in them... but quickly ran into a brick wall when some settings were turned up. Running games in Surround became an exercise in determining what settings I could or couldn't enable on a "per game" basis and still maintain a playable framerate. It was no easy matter – many times the games played well until one setting was pushed a tiny bit too far, at which point the game would nosedive from a comfortable 30+fps or 40+fps to low teens or in some cases even single digit framerates.<br><br>
Now, it can be argued that the GTX460, as nVidia's "mainstream" card, simply is not capable of running the vast Surround resolutions at ultra-high details and maintain a decent framerate. My early observations, aided by MSI Afterburner and my G15 LCD, allowed me to create a hypothesis which I will attempt to prove (or disprove) in this review. It was quite simple; whenever Afterburner reported that VRAM usage was close to 100% of the cards VRAM, framerates nosedived – I believed that it was at this point that the system was swapping to system RAM and the latencies and bandwidth decrease resulted in huge framerate losses.<br><br>
Therefore, let's propose the hypothesis:<br><br><b><i>At Surround resolutions, games are heavily VRAM limited.</i></b>
Discussion Starter #2
For these tests, I have the following system:<br><br>
Core i7 920 (at stock)<br>
6GB 1600MHz Corsair XMS3<br>
Gigabyte EX58-UD5<br>
Samsung Spinpoint F1 1TB<br>
Logitech G15 keyboard (for LCD readouts of MSI Afterburner)<br>
Dell 2405WFP, Dell U2410, Dell 2405WFP in that arrangement, totalling 5760x1200 (6064x1200 with bezel correction)<br><br>
Software used for these tests includes:<br>
Windows 7 Home Premium x64, GPUz, MSI Afterburner, MSI Kombustor, Aliens vs. Predator (2010), DiRT 2, Burnout Paradise, Just Cause 2, Half Life 2: Lost Coast, Devil May Cry 4, Crysis, Far Cry 2, Need for Speed: Shift, Grand Theft Auto IV and S.T.A.L.K.E.R: Clear Sky. Reasons for these games? I own them, and with the exception of Far Cry 2, like them. Many of them support multi-display correctly (AvP, Dirt2, BP, JC2, DMC4, FC2, NfS:S, GTAIV) and those that don't (HL2:LC, S:CS) do treat Surround reasonably well. Many are quite GPU intensive as well; particularly Just Cause 2 and Aliens vs. Predator.<br><br><b>NB:</b> This was not carried out on a clean install of Windows 7, so a virgin install may yield slightly higher numbers. This was also done with my gaming rig in its normal state, with an 'on demand' rather than an 'on access' virus scanner installed, and anti-Spyware programs, along with any other drivers or background processes that things have installed. However, all processes running are what I deem 'necessary' for the continued operation and wellbeing of the system.<br><br>
If games contained an internal benchmark, it was evaluated initially for its ability to mimic real gameplay. If it was deemed unable to, or the game lacked a benchmark, actual gameplay was used. This will be detailed further in the relevant sections. I am sensitive to low framerates at different points in different games. In Just Cause 2, I would notice a framerate drop very quickly; in other games such as Need for Speed: Shift, the framerate would have to dip lower than in Just Cause 2 to make me notice. This is obviously subjective, but it's the best I can do right now.<br><br>
The purpose of these tests isn't low resolutions. 1920x1200 is there as a comparison to a single screen setup, but it's the Surround resolutions which are interesting.<br><br>
Under test we have:<br><br><div style="text-align:center;"><b>Palit GTX460 Sonic 1GB (x2)</b><br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/GTX460%201GB%20GPUz.png" style="border:0px solid;"></div>
Figure 1: GPU-z readout of the 1GB Palit GTX460s used in testing. Note that GPU-z reports the Shader count incorrectly as 224 shaders, when it is in fact 336. Cards were tested at stock clocks of 700/1400/3600 (core/shader/memory) respectively.<br><br><div style="text-align:center;"><b>Palit GTX460 Sonic 2GB (x2)</b><br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/GTX460%202GB%20GPUz.png" style="border:0px solid;"></div>
Figure 2: GPU-z readout of the 2GB Palit GTX460s used in testing. Note that GPU-z reports the Shader count incorrectly as 224 shaders, when it is in fact 336. Cards were tested at stock clocks of 700/1400/3600 (core/shader/memory) respectively.<br><br>
First, differences between the cards: the only physical differences between the cards are an extra set of memory chips soldered on the back of the 2GB cards. Clocks are the same on all (700MHz core, 1400MHz shader, 3.6GHz memory) but the 2GB cards have a higher default VDDC (GPU Vcore) of 1.025v rather than 0.987v. I overclocked them quickly with MSI Afterburner and got the 1GB cards to 800MHz (stable) without any problems at stock VDDC (0.987v). The 2GB cards performed likewise, stable at 800MHz with stock VDDC of 1.025v. I have not, at this present time, tested further – due to my motherboard, GPU1 is sandwiched right up against GPU2, and gets... rather hot. When I was running the 1GB cards, I saw GPU1 hit 96ºC in DiRT 2 at one point, and while GPU1 of the 2GB cards only reached 90ºC, I am confident that this is due to decreased ambient temperatures on the day of testing the 2GB cards. Given that GPU2, which has more room to 'breathe', never breaks 65ºC, I would very much like to get a motherboard which puts two slots between the GPUs rather than one... such as the Asus P6T Deluxe. I believe this would yield greatly reduced GPU1 temperatures.
<b>GTX460 SLI Surround Benchmarks</b><br><br>
I will provide results obtained first with an SLI setup of two 1GB cards, followed by results obtained from an SLI setup of two 2GB cards, for each game tested. Some discussion will occur at each stage, with a general discussion and overall conclusion at the end of the review.<br><br>
Games will be quickly detailed and their Surround support quantified by a four step scale; excellent, good, poor or abysmal.<br><br><b>Aliens vs. Predator (2010)</b><br><br><i>Genre: First Person Shooter</i><br><i>Surround Support: Excellent</i><br><br>
Aliens vs. Predator was benched with the following settings: DirectX 11, 16xAF, High Shadow Quality, SSAO On, Hardware Tesselation enabled, Advanced Shadow Sampling enabled. Texture quality, resolution and antialiasing were varied, although only the results from 'Very High' texture quality are shown here. AvP is a demanding next-generation title which takes advantage of DirectX 11 capable hardware such as the GTX460. I am not very far in this game, so used the downloadable benchmark which in analysis appeared to give similar results to the numbers I have been seeing when actually playing the game.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/AvP%201GB.png" style="border:0px solid;"><br>
Figure 3: Aliens vs. Predator results working with SLI 1GB GTX460s.<br><br>
With a pair of 1GB GTX460s in Surround, it is obvious that Aliens vs. Predator is barely able to keep up at Surround resolutions, and is absolutely impossible with Anti-Aliasing applied at a triplescreen res. If details are dropped to High, oddly framerate decreases further (data not shown).<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/AvP%202GB.png" style="border:0px solid;"><br>
Figure 4: Aliens vs. Predator results working with SLI 2GB GTX460s.<br><br>
Once a pair of 2GB cards are in use, it is a different story. AvP is just playable with a minimum framerate of 22fps at a bezel corrected resolution of 6064x1200. Those playing at 5760x1080 (or lower, with WSXGA+ panels) should be able to achieve more than playable framerates in AvP. The increased VRAM has the most marked effect of an increase in minimum framerate, even in scenarios where the game is already performing acceptably with 1GB.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/AvP%20VRAM.png" style="border:0px solid;"><br>
Figure 4: VRAM usage at different resolutions in Aliens vs. Predator.<br><br>
Note that at 6064x1200 4xAA, even the 2GB card appears to run into a VRAM limit, albeit a minor one. This demonstrates very well that a 1GB card does not have enough VRAM to cope with the demands of a DX11 title with all the bells and whistles added. The low readings on the 1GB cards for 5760x1200 4xAA and 6064x1200 4xAA can be attributed to the game attempting to page VRAM data to system RAM, and failing to fill the VRAM as a result. When Alt-Tab was used to move out of the benchmark at one point (during a run where no data was collected) Task Manager reported no free system RAM (of 6GB), presumably it was further utilising the pagefile on the hard drive.<br><br>
-----<br><br><b><span style="text-decoration:underline;">DiRT 2</span></b><br><br><i>Genre: Racing<br>
All settings at maximum, including Post Processing at 'High'. Resolution and AA varied. I quite like DiRT2, so decided to bench based on a player-controlled race: Battersea, three laps, 7 opponents, starting at the back of the grid.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/DiRT2%201GB.png" style="border:0px solid;"><br>
Figure 5: DiRT 2 results working with SLI 1GB GTX460s.<br><br>
DiRT2 appears to have a built-in framerate cap at 60fps. I made sure I disabled Vsync both in game and in nVidia Control Panel, yet I never saw more than 60fps (even tried 1024x768 to make sure...) as with AvP, it is evident that the 1GB cards cannot cope with Surround at maximum settings. However, I was able to play DiRT 2 with Post Processing on Medium and 0xAA at 6064x1200 on 1GB cards and maintain a minimum of 40fps (data not shown). If I have enough time over the next few weeks, I will go back and slowly step all the settings up from minimum one at a time to show where this VRAM bottleneck occurs. DiRT 2 does appear to suffer from severe performance decreases with bezel correction enabled on 1GB cards. While I would not call 5760x1200 playable, the 7fps minimum occurred in the pre-race camera panning – during racing itself, FPS never dropped to a point where it was noticeably jerky, thus I presume that it was at least 20fps during racing at all times.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/DiRT2%202GB.png" style="border:0px solid;"><br>
Figure 6: DiRT 2 results working with SLI 2GB GTX460s.<br><br>
With 2GB cards, framerates pick up exceptionally. In fact, I never intended to test 6064x1200 8xAA, but the framerate at 4xAA was still good, so I decided to try it. This resulted in a very interesting result: average fps was easily playable, but during the pre-race camera pan fps was single digits and after I crossed the finish line framerate actually reported 0fps for a second.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/DiRT2%20VRAM.png" style="border:0px solid;"><br>
Figure 7: VRAM usage at different resolutions in DiRT 2.<br><br>
Looking at the VRAM usage figures, hopefully it becomes evident why 6064x1200 8xAA hit such a performance brick wall: even on a card with 2GB of VRAM, DiRT 2 at this resolution and settings fills it and wants more. Those final few MB of 2048 are needed for each rendered frame – at 6064x1200 each frame displayed takes up 27.76MB in the graphics card VRAM. Again it is interesting to see that the 1GB cards fail to fill the VRAM at extreme settings before choosing to use system RAM instead.
Reactions: LOL_Wut_Axel
Discussion Starter #4
<b><span style="text-decoration:underline;">Burnout Paradise</span></b><br><br><i>Genre: Racing<br>
All settings at max, except SSAO which was off. Even at 1920x1200, SSAO makes framerates tank. Game is capped at 60fps regardless of forcing Vsync off in Control Panel. Resolution and AA varied. I chose to drive around Paradise in a Jensen X12 (which is fast) as the game dynamically loads textures as it needs them – I would start in the East of Paradise City and drive West through the city to the Wind Farm. This involves a lot of traffic, and a lot of textures change. This makes the texture buffering work hard to swap required textures in and out as necessary. SSAO was OFF, as it makes framerates tank regardless of resolution.<br><br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/BP%201GB.png" style="border:0px solid;"><br>
Figure 8: Burnout Paradise framerates on a 1GB GTX460 SLI setup.<br><br>
Burnout Paradise, even at maximum (not including SSAO) is quite obviously not the most demanding of games. It runs well at all resolutions, and like DiRT 2, exhibits an obvious 60fps framerate cap.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/BP%202GB.png" style="border:0px solid;"><br>
Figure 9: Burnout Paradise framerates on a 2GB GTX460 SLI setup.<br><br>
With 2GB cards, the framerate cap becomes the limiting factor. It is plainly evident that even the highest settings are fully playable at extremely high resolutions in Burnout Paradise.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/BP%20VRAM.png" style="border:0px solid;"><br>
Figure 10: VRAM utilisation in Burnout Paradise at different resolutions and AA levels.<br><br>
Looking at the VRAM usage shows why Burnout Paradise runs so well: even at high resolutions, the only time it really eats VRAM is at 6064x1200 8xAA. Burnout Paradise actually gives a good opportunity to look at something else: VRAM usage is not quite so efficient on the 2GB cards as the 1GB ones. At the same settings, a 2GB card will always use a few more MB of VRAM than a 1GB card. A limitation of the memory controller? This may be examined in more detail in the future if I am able.<br><br>
-----<br><br><b><span style="text-decoration:underline;">Just Cause 2</span></b><br><br><i>Genre: Open World Action/ Third Person Shooter<br>
All settings at maximum except shadows on medium, SSAO off, Vsync off, GPU water off.<br><br>
Here is a game I didn't test in 5760x1200. I don't know quite why, but in Just Cause 2, if bezel correction is disabled, I want to puke. The built in benchmarks do not appear to be representative of actual gameplay. Dark Tower reports too high framerates, as does Desert Sunrise. Concrete Jungle, in comparison, has several points where framerates tank. Thus this involved me loading a savegame, making my way from a beach across a stretch of water, over trees with the parachute before blowing stuff up at one of the bases. So results are for 6064x1200 only.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/JC2%201GB.png" style="border:0px solid;"><br>
Figure 11: Framerates obtained in Just Cause 2 with 1GB GTX460 SLI.<br><br>
From the framerates of 6064x1200 it should be evident that 1920x1200 is going to be more than playable on 1GB GTX460 SLI. In fact originally (pre-Surround) I was getting 50-55fps on a 4870X2 in Just Cause 2, which jumped to 80-95fps with GTX460 SLI. Without anti-aliasing, Just Cause 2 is extremely playable at Surround resolutions. I didn't even notice that the framerate dipped to 20fps at one point.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/JC2%202GB.png" style="border:0px solid;"><br>
Figure 12: Framerates obtained in Just Cause 2 with 2GB GTX460 SLI.<br><br>
But it is immediately evident that with 2GB to VRAM to play with, framerates are vastly improved.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/JC2%20VRAM.png" style="border:0px solid;"><br>
Figure 13: VRAM use in Just Cause 2 at 6064x1200.<br><br>
Looking at the VRAM usage reveals why enabling anti-aliasing results in a framerate drop. It also shows that Just Cause 2 is remarkably VRAM efficient in Surround.<br><br>
Out of curiosity, I did some more testing with Just Cause 2: just how much VRAM could I get it to gobble, and how playable would it be? Well, the short answer is; lots, and not very. Turning anti-aliasing up to frankly ridiculous levels (and I believe I may have found a bug, as the game actually looked fairly ugly with 16x(Q)CSAA enabled – textures lacked sharpness and definition, edges were badly muddied) took VRAM usage from 1368MB with 4xAA to 1742MB. Which, to me, didn't seem like a great increase from a very large jump in AA level – perhaps the CSAA implementation is more VRAM efficient? Enabling SSAO uses 250MB of VRAM instantly. No wonder it had such impact when enabling on a 1GB card...<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/JC2%20SHS.png" style="border:0px solid;"><br>
Figure 14: Just Cause 2 framerate in extreme scenarios.<br><br>
What was interesting was that SSAO and stupidly high levels of AA have the same sort of impact in framerate terms; combine them and it doesn't make the situation a whole lot worse but it still doesn't make it playable.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/JC2%20SHS%20VRAM.png" style="border:0px solid;"><br>
Figure 15: Just Cause 2 VRAM usage in extreme scenarios.
Discussion Starter #5
<b><span style="text-decoration:underline;">Half Life 2: Lost Coast</span></b><br><br><i>Genre: First Person Shooter<br>
Surround Support: Good</i><br><br>
Everything at maximum, resolution varied. 4xAA.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/HL2LC%201GB.png" style="border:0px solid;"><br>
Figure 16: Half Life 2: Lost Coast framerate at different resolutions with a 1GB GTX460 SLI setup.<br><br>
Framerates are excellent no matter what. Not surprising, as Half-Life 2 is showing its age now.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/HL2LC%202GB.png" style="border:0px solid;"><br>
Figure 17: Half Life 2: Lost Coast framerate at different resolutions with a 2GB GTX460 SLI setup.<br><br>
Half-Life 2: Lost Coast is, in fact, the first of two games tested which do not take the extra VRAM offered by the 2GB cards and run with it. Mostly, this is because it just doesn't need that much VRAM. I will be trying this again with the FakeFactory Cinematic Mod 10 in due course as that is much more demanding. It is interesting that the increase in VRAM has a significant impact on minimum framerates, but at >100fps, it's hardly worth worrying about.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/HL2LC%20VRAM.png" style="border:0px solid;"><br>
Figure 18: Half-Life 2: Lost Coast VRAM usage in Surround scenarios.<br><br>
Half-Life 2: Lost Coast appeared not to be overly concerned about VRAM, using if it was there and needed, but otherwise it wasn't framerate tanking the way other games did.<br><br>
There is one important issue with Half-Life 2: Lost Coast: in Surround (5760x1200 or 6064x1200) there is some significant graphical corruption on some textures. Wherever water touched, textures were purple. Still textures; they were just tinted purple. This was not observed at 1920x1200. FFCM10 was not tested, so I do not know if that would fix it.<br><br>
-----<br><br><b><span style="text-decoration:underline;">Devil May Cry 4</span></b><br><br><i>Genre: Action Fantasy<br>
All settings at "Ultra". Resolution and AA varied. I used the built-in benchmark; I would have done a run through of the second mission, "La Porte de l'Enfer" as I quite like that level, but didn't feel like playing it 24 times!<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/DMC4%201GB.png" style="border:0px solid;"><br>
Figure 19: 1GB GTX460 SLI framerates obtained in Devil May Cry 4.<br><br>
All resolutions and levels of AA were extremely playable with 1GB cards.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/DMC4%202GB.png" style="border:0px solid;"><br>
Figure 20: 2GB GTX460 SLI framerates obtained in Devil May Cry 4.<br><br>
2GB cards made little to no difference in framerates obtained except at 8xAA in Surround.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/DMC4%20VRAM.png" style="border:0px solid;"><br>
Figure 21: Devil May Cry 4 VRAM usage at different resolutions.<br><br>
Devil May Cry 4 is the second game that does not appear to be particularly sensitive to VRAM usage exceeding 1GB. This is probably largely due to it already having extremely high framerates to begin with.
Discussion Starter #6
<b><span style="text-decoration:underline;">Crysis</span></b><br><br><i>Genre: First Person Shooter<br>
DX10, 64-bit, settings set to Very High, Resolution varied.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/Crysis%201GB.png" style="border:0px solid;"><br>
Figure 22: Framerates on 1GB GTX460 SLI in Crysis.<br><br>
Here is where I begin to think that testing Crysis at Very High was a mistake. Couldn't enabled 4xAA on the 1GB cards without it trying to crash. Not sure what's up there.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/Crysis%202GB.png" style="border:0px solid;"><br>
Figure 23: Framerates on 2GB GTX460 SLI in Crysis.<br><br>
1920x1200 is playable. Others are not. Need to retest on something more reasonable, like a mixture of medium/high as that is where I actually play Crysis and it still looks good.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/Crysis%20VRAM.png" style="border:0px solid;"><br>
Figure 24: Crysis VRAM usage at different resolutions.<br><br>
One thing to say: VRAM hog!<br><br>
I don't think a GTX460 SLI setup could handle Crysis at Very High even if it wasn't munching VRAM for breakfast... but that nearly 1500MB used at 1920x1200 makes me wonder if a 480 would be the only real option. Even then, it needs more VRAM for Surround. Come on, someone, release a 3GB GTX480! Again, VRAM utilisation isn't good on the 1GB cards – still seems to go for system RAM preferentially if it's not got enough on the GPU.<br><br>
-----<br><br><b><span style="text-decoration:underline;">Far Cry 2</span></b><br><br><i>Genre: First Person Shooter<br>
Surround Support: Excellent (with latest patch)</i><br><br>
D3D10, Fixed Time Step(No), Disable Artificial Intelligence(No), Full Screen, Anti-Aliasing(8x), VSync(Yes), Overall Quality(Custom), Vegetation(Very High), Shading(Ultra High), Terrain(Ultra High), Geometry(Ultra High), Post FX(High), Texture(Ultra High), Shadow(Ultra High), Ambient(High), Hdr(Yes), Bloom(Yes), Fire(Very High), Physics(Very High), RealTrees(Very High). Resolution and AA varied. Boring game. But benched because the engine is technically very good. Would be interested in seeing a decant game using the Dunia engine, rather than it being a Far Cry 2 exclusive.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/FC2%201GB.png" style="border:0px solid;"><br>
Figure 25: Framerates on 1GB GTX460 SLI in Far Cry 2.<br><br>
The 8xAA run was mostly out of curiosity, as aside from an atrocious minimum framerate, 6064x1200 4xAA was rather playable. Lots of flame was the cause of that 13fps.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/FC2%202GB.png" style="border:0px solid;"><br>
Figure 26: Framerates on 2GB GTX460 SLI in Far Cry 2.<br><br>
And with more VRAM, Far Cry 2 sings. Butter smooth and gorgeous the whole way through, even up to 8xAA. Not sure why 4xAA at 1920x1200 doesn't have a performance impact on the 2GB card. It's impact is minimal on the 1GB cards anyway.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/FC2%20VRAM.png" style="border:0px solid;"><br>
Figure 27: Far Cry 2 VRAM usage at different resolutions.<br><br>
The anti-aliasing implementation in Far Cry 2 is rather VRAM hungry. Only an extra 400MB of VRAM used for a 3x jump in resolution is impressive, though.<br><br>
Overall, I'm very impressed with how Far Cry 2 deals with Surround. If only it was a more enjoyable game...
Discussion Starter #7
<b><span style="text-decoration:underline;">Need for Speed: Shift</span></b><br><br><i>Genre: Racing<br>
Data was taken from a three lap race on Alpenal, with 9 opponents, starting from the last place on the grid. All settings at maximum, resolution and AA varied.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/NfSS%201GB.png" style="border:0px solid;"><br>
Figure 28: Framerate in Need for Speed: Shift with 1GB GTX460 SLI.<br><br>
Here is an interesting situation that draws questions about how nVidia handle their bezel correction algorithm, and how it actually functions. Non-bezel corrected Surround is playable, while bezel corrected Surround is not. Any anti-aliasing at Surround resolutions results in a slideshow. The framerate impact of bezel correction is in the order of 20-25% of the fps, while the actual resolution increase is only 5%. Is this a situation similar to GRID, where bezel correction actually causes the game to crash on loading? Well, it's obviously not causing a crash, but bezel correction is having an impact somewhere in the background that we can't see.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/NfSS%202GB.png" style="border:0px solid;"><br>
Figure 29: Framerate in Need for Speed: Shift with 2GB GTX460 SLI.<br><br>
With the 2GB cards, the bezel correction framerate impact is still evident, but framerates are actually playable. Even 6064x1200 4xAA was easy to race, although I would pick 0xAA myself for those extra few fps which might make a difference. If able to play without bezel correction in Need for Speed: Shift, do so as it saves a fair few frames per second from vanishing into the ether.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/NfSS%20VRAM.png" style="border:0px solid;"><br>
Figure 30: VRAM usage in Need for Speed: Shift.<br><br>
Another extremely VRAM hungry game at Surround resolutions...<br><br>
-----<br><br><b><span style="text-decoration:underline;">Grand Theft Auto IV</span></b><br><br><i>Genre: Action/Third Person Shooter<br>
Surround Support: Good (some minor minigame blemishes)</i><br><br>
Everything at maximum. Everything. Draw distance, the whole lot. Resolution varied. Save game loaded and a car taken for a spin.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/GTAIV%201GB.png" style="border:0px solid;"><br>
Figure 31: FPS in GTA IV on a 1GB GTX460 SLI setup.<br><br>
To even get GTA IV to acknowledge Surround resolutions I needed to enable the –nomemlimit –norestrictions switches, and while the game would load to the menu at Surround resolutions, it would fail to load a savegame, just sitting on 'Loading' forever. I actually went to make dinner and eat it when waiting to see if GTA IV would do anything, and it was still supposedly 'Loading'.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/GTAIV%202GB.png" style="border:0px solid;"><br>
Figure 32: FPS in GTA IV on a 2GB GTX460 SLI setup.<br><br>
While the 2GB cards allowed GTA IV to load and play without issues. This was smooth and playable.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/GTAIV%20VRAM.png" style="border:0px solid;"><br>
Figure 33: VRAM usage of GTA IV.<br><br>
GTA IV is unique out of the games I've tested here for appearing to have a bit of a VRAM memory leak going on. While other games fill VRAM as they are loading, GTA IV starts off and uses nowhere near as much VRAM as it estimates it will for a particular setting and resolution. By the time you've been driving around for a few minutes, VRAM usage has just kept increasing and increasing. For example, on the 2GB cards when it first loads it uses less than 700MB of VRAM. That 1495MB value above is after five minutes or so of driving around.
Discussion Starter #8
<b><span style="text-decoration:underline;">S.T.A.L.K.E.R: Clear Sky</span></b><br><br><i>Genre: First Person Shooter<br>
Downloadable benchmark utilised (average of the 4 flybys used) as while I like the STALKER games, I didn't have the patience to want to actually play it right now. All settings at maximum, DX10.1, etc...<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/STALKER%201GB.png" style="border:0px solid;"><br>
Figure 34: S.T.A.L.K.E.R: Clear Sky framerates on 1GB GTX460 SLI.<br><br>
Normal 16:10 gaming was perfectly possible even with 4xAA enabled. Surround gaming is far less comfortable, with the minimum fps being extremely noticeable in this title for some reason. Surround + AA absolutely impossible.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/STALKER%202GB.png" style="border:0px solid;"><br>
Figure 35: S.T.A.L.K.E.R: Clear Sky framerates on 2GB GTX460 SLI.<br><br>
Surround minimum framerates reaching into a more playable zone with a 2GB card, but enabled AA and STALKER is impossible at Surround resolutions.<br><br><img alt="" src="http://www.wsgfmedia.com/paradigm/GTX460/STALKER%20VRAM.png" style="border:0px solid;"><br>
Figure 36: S.T.A.L.K.E.R: Clear Sky VRAM usage.<br><br>
A quick look at the VRAM utilisation numbers shows exactly why AA makes the 1GB cards tank so badly. However, STALKER, Aliens vs. Predator and Crysis are really the only games tested here which I can honestly say a 2GB GTX460 SLI setup isn't powerful enough to cope with at (near)-full details in Surround resolutions.<br><br>
-----<br><br><span style="text-decoration:underline;"><b>General Discussion</b></span><br><br>
Of the eleven games tested here, six of them performed acceptably on a 1GB GTX460 SLI Surround setup. If more cautious about settings utilised, a further two would become playable (DiRT 2 needs Post Processing disabled on 1GB cards and Aliens vs. Predator needs DX11 features disabled) without anti-aliasing.<br><br>
If, on the other hand, you wish to be able to run with at least a low level of anti-aliasing, or be less picky about exactly what detail settings you enable, the 2GB cards allow a far more consistent experience across the board. There are really only two games that are out of reach in terms of playability on maximum settings in Surround with a 2GB GTX460 SLI setup... those are S.T.A.L.K.E.R: Clear Sky and Crysis. While perhaps it is unfair to immediately write these two games off, it is widely acknowledged that Crysis still has yet to meet a graphics card which can handle it with no sweat whatsoever, and S.T.A.L.K.E.R is also notorious for being something of a system killer at higher detail settings. Two games (Half-Life 2 and Devil May Cry 4) have no problems in Surround at any resolution or anti-aliasing level you care to throw at them, while three of the others (Aliens vs. Predator, DiRT 2 and Just Cause 2) need some careful analysis of what settings are going to be enabled or disabled to have them fully playable in Surround on what has demonstrated itself to be a fantastic mainstream card.<br><br>
Those who have examined the VRAM usage graphs in particular I hope will note that in many cases (Crysis being the notable exception) that the increased VRAM offered by 2GB cards can make all the difference between something being playable and it not.<br><br>
I hope that it is also evident that Surround resolutions (and any ultra-high-resolution scenario such as TripleHead2Go or EyeFinity) that VRAM availability is extremely important. While obviously VRAM alone will not make an underpowered GPU capable of pushing frames with the top-end cards, for Surround a good mainstream backed by a larger than normal quantity of VRAM appears to be a winning combination.<br><br><span style="text-decoration:underline;"><b>Future Work</b></span><br><br>
At this present time, I have other commitments which must be met, but pending sufficient time in the future I would very much like to carry out the following extensions to this investigation:<br><ul><li>Observation of 'best playable settings (with a defined minimum framerate) for each game tested here.</li>
<li>Lower resolution testing (not done as currently selecting non-native Surround res on my system results in it going straight back to 5760x1200 on the desktop...)<br></li>
<li>Crysis – lower detail settings, anti-aliasing.</li>
<li>S.T.A.L.K.E.R – lower detail settings.</li>
<li>Just Cause 2 – lower detail settings.</li>
<li>Aliens vs. Predator – lower detail settings.</li>
<li>Use of FakeFactory's Cinematic Mod 10 for Half-Life 2 testing.</li>
</ul><br><span style="text-decoration:underline;"><b>Conclusion</b></span><br><br>
For those on a budget, or not wishing to worry about the power draw or heat output of a full-fat GF100 SLI setup, but still wanting to enter Surround gaming, the 2GB GTX460 presents an unrivalled opportunity to do so. Given the little extra cost of a 2GB card over a 1GB card, there is no reason now they are available to go with 1GB cards and risk a 'settings lottery' of whether a particular detail setting will push the game into single-fps territory.<br><br>
Obviously, for those running single screen systems, a 2GB card is just overkill. But as already said, for those wanting Surround on a "budget"... a pair of 2GB GTX460's for three cheap 1920x1080 or 1920x1200 screens can't go wrong.<br><br>
...<br><br>
I hope this has been of help, folks. <img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment">
Good thing I won't be trying surround using my 460's anyway.
maybe getting a pair of used 1792mb GTX 260s or GTX 275s would be a good route then?
<div>Originally Posted by <strong>sgdude</strong> <a href="showthread.php?s=5bd08cb0a2becf66ff9a516b8d226d15&p=10359319#post10359319"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">maybe getting a pair of used 1792mb GTX 260s or GTX 275s would be a good route then?</div>
</td>
</tr></table></div>
Don't think those have surround. . .<br><br>
Anyway, good results. . .<br><br>
SLI 460 1gb are still pretty good on a single monitor.
<div>Originally Posted by <strong>WTHbot</strong> <a href="showthread.php?s=5bd08cb0a2becf66ff9a516b8d226d15&p=10359386#post10359386"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">Don't think those have surround. . .</div>
</td>
</tr></table></div>
They do support it.<br><a href="http://www.nvidia.com/object/3dv-system-requirements-surround-technology.html" target="_blank">http://www.nvidia.com/object/3dv-sys...echnology.html</a>
Discussion Starter #13
<tr>
<div>
<a href="showthread.php?s=5bd08cb0a2becf66ff9a516b8d226d15&p=10359319#post10359319" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">maybe getting a pair of used 1792mb GTX 260s or GTX 275s would be a good route then?</div>
</td>
</tr>
</table>
</div>Yeah, it wouldn't be a bad idea. Most of nVidia's efforts on the Surround front seem to be focussed on Fermi-based cards, though. GT200 series Surround really seems like more of a stop-gap for those already running GT200 (tri)-SLI and want to try Surround without jumping on yet more expensive hardware.<br />
<br />
If I had owned GT200 hardware, I'd have tried it that way first, but I didn't. (Have been using ATi hardware for the last couple of years, but I've never been brand loyal anyway... <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />)<br />
<br />
Surround wants VRAM. A lot.<br />
<br />
Makes me look at the GTX480 and think, "If it had 3GB of RAM, I'd do it, but 1.5GB just isn't enough..."<br />
<br />
<tr>
<div>
<a href="showthread.php?s=5bd08cb0a2becf66ff9a516b8d226d15&p=10359386#post10359386" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Don't think those have surround. . .<br />
<br />
Anyway, good results. . . <br />
<br />
SLI 460 1gb are still pretty good on a single monitor.</div>
</td>
</tr>
</table>
</div>Yup, they do. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
Thanks.<br />
<br />
And yes, SLI 1GB GTX460s are still a great combination for single monitor, and they can do Surround... you just need to be <i>really</i> careful what settings you use. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Reactions: brettjv
Very, very nice work PS.<br><br>
Thanks for doing all that ... must've taken fricking FOREVER.<br><br>
Pretty much shows what I'd expect to see, but it's nice to have my suspicions confirmed.<br><br>
Really impressive job <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Discussion Starter #15
Thanks, mate. It certainly took a while, although once I figured out the best of of doing stuff, it wasn't too bad. Getting the numbers took a couple of days, crunching the numbers took <i>ages</i>... <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
Hopefully this helps anyone who wants to go Surround but isn't sure about the demands of such a high-res system.
Reactions: MoBeeJ and HAVO
Nice.
Discussion Starter #17
Gracias. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
Anyone got any questions, or did I cover this to everyones satisfaction? I've still got more I want to do (as I mentioned) but I've got a couple of other things I need to do first before I get on any of those.
Wow sick review mate, so my 260s 896mb might not be enuf at high res 1920 x 1080 x 3<br><br>
damn lol<br><br>
and can you run surround off a single 460?<br><br>
Cheers
Performance is the bible
<div>Originally Posted by <strong>Fallen Angel -X</strong> <a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=10367853#post10367853"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">and can you run surround off a single 460?</div>
</td>
</tr></table></div>
No, surround requires 2 cards.<br><br><br><br>
Also, for the OP,<br>
that is the same reason the 5xxx series have 2GB high end cards.<br>
Since a single card can handle the eyefinity setups, but they requires alot more memory to go higher on details.<br>
The eyefinity6 versions for example, or the 5970 4gb card, are good examples.<br>
Even a 5970 with 2GB has issues when it comes to pushing it in eyefinity. Increasing memory speeds help, but only to a certain point.
I.T. Specialist III
Wow very nice + rep.
1 - 20 of 72 Posts
