1 - 2 of 2 Posts
Hi.
I recently downloaded Cedega and installed it on my computer at home.
It worked fine there with my Suse 10.1, but when i try to install it on a different computer it will not install and gives me the message "The filename "cedega-5.1-1.i386.rpm" indicates that this file is of type "RPM package". The contents of the file indicate that the file is of type "plain text document". If you open this file, the file might present a security risk to your system.
Do not open the file unless you created the file yourself, or received the file from a trusted source. To open the file, rename the file to the correct extension for "plain text document", then open the file normally. Alternatively, use the Open With menu to choose a specific application for the file. "
Does anyone know how to override this and make it install?
I've tried running it with installer, but it just says that no installable packages are found.
Thanks.
It worked fine on SuSE 10.1 and then what is the other computer running that your trying to put it on?
If its SuSE 10.1 too then try the following:
cd /*to the directory the file is in
chmod +x cedega-5.1-1.i386.rpm
then run the RPM.
1 - 2 of 2 Posts
