1 - 9 of 9 Posts
xine ui, MPlayer, and Movie Player closes before anything loads...runs no longer than half a second. Kaffeine and Noatun stays on but doesn't play my files (.avi, .mpeg- divx,xvid?) Running GNOME
you will need codecs etc.<br>
Take a look at my faq<br><a href="http://www.overclock.net/faqs/104037-how-get-mp3-divx-video-support.html" target="_blank">http://www.overclock.net/faqs/104037...o-support.html</a>
<div>Originally Posted by <strong>Squeeky</strong></div>
<div style="font-style:italic;">you will need codecs etc.<br>
Take a look at my faq<br><a href="http://www.overclock.net/faqs/104037-how-get-mp3-divx-video-support.html" target="_blank">http://www.overclock.net/faqs/104037...o-support.html</a></div>
</td>
</tr></table></div>
=) this is after doing what's in your faq<br>
I couldn't install the files using -i, though...it says<br>
bash: -i: command not found<br>
so I installed it by just clicking on it...I think it used something called zeninstaller or something.
um it tells you how to install codecs xvid divx etc. You can also get the libs for dvd playing if you know where to look but i cant include that as in some places it isnt legal cos of lisencing
Discussion Starter #5
I think I installed the codecs correctly, but there's something wrong with the players. When I open it, it closes before I even blink!
mm ok ill look in to it for you
Discussion Starter #7
<div style="font-style:italic;">mm ok ill look in to it for you</div>
</td>
</tr></table></div>
Thanks. I just need to get divx and xvid to work...don't recall the last time i used my dvd drive anyway.
id try getting new rpms from that faq i mentioned and reinstalling xine-libs and xine etc
Discussion Starter #9
<div style="font-style:italic;">id try getting new rpms from that faq i mentioned and reinstalling xine-libs and xine etc</div>
</td>
</tr></table></div>
How do you reinstall? If I just double click, it says that it's already installed. I used the GNOME Terminal and typed rpm -i *.* with all the files in a folder, but it says that they're already installed...do I have to uninstall them? If so, how? I thought of this before but didn't know how to reinstall, so I reinstalled suse 10.1.
1 - 9 of 9 Posts
