Originally Posted by
CynicalUnicorn
660Ti was a 670 with a gimped back-end. This is supposedly similar to Tahiti with a gimped back-end... So it's a higher model number?
Roaches
660, 660 TI, and 670 were nothing more than rejected chips of the same GK-104 die. Tonga is likely a new silicon die based off GCN, likely with improvements and lessons learned from Hawaii architecture. I don't see how that is the same as this.
It reminded me of it because both the 660 Ti and the 285 have a gimped memory bus and the same core count over their closest counterparts, however the thing which sets them apart is the 285's higher model number over the 7970GHz/280X which may or may not be an indication of the level of performance.
660 Ti, 192bit, 670, 256bit, less memory bandwidth however with same core count.
285, 256bit, 7970, 384bit, same core count however with less memory, I'm not sure about the memory bandwidth. (Is it directly affected by the bus width?)
If the higher model number is a measure of performance for this card, it could mean that there's been some performance improvements in the architecture, or maybe it's clocked higher than the 7970?
