1 - 7 of 7 Posts
I need to convert some .swf files to mp3 (just need the audio). I tried TMPGEnc and Magic Video Converter, neither worked. I think it's some problem with my installed codecs (K-Lite + ACE Mega Codec) I need something with built-in codec so it doesn't uses my codec. Thanks.
Reactions: awdrifter
Thanks for the reply. I just tried to use the swf extractor, it gave me a "data error". I tried two swf files, both of them gave me the same error.
hi, you may try Nidesoft video converter, this converter can convert between almost all popular video and audio formats in high quality at fast speed, it is also easy to use, you may free download it here to have a try:
http://www.nidesoft.com/video-converter.html
it has built-in code, you needn't do more settings, you just need to choose mp3 profile
here you can get guide to how to use this converter in details:
http://bestvideoconvertersoftware.blogspot.com/
hope my information helps you
1 - 7 of 7 Posts
