21221 - 21240 of 21297 Posts
Gamer
Still using the original H320 (in push/pull) that Swiftech unfortunately had to stop selling due to some patent crap a while back. The cooler is a beast and amazing still do this day like, I don't know, around 5-7 years later or something. It cooled overclocked/overvolted 4930Ks, a 5930K, an 8700K and now a 9700K like a beast. It laughs at the 9700K at 5.2 GHz in the 1.35v - 1.38v area (as long as not using crazy AVX, lol). I have the slightly updated revision of the original H320 which included an upgraded/revised pump (if I remember correctly, the revised version can be distinguished with 3 cables instead of 2 coming out of the pump/block or something like that). Anyways, I just want to say the Swiftech H320 is amazing and going strong as hell still to this day and with modern, overclocked/overvolted processors. Easily the best cooler I've owned in my life.
LOL!!! I don't know dude, something about Mayhems just does not sit right with me.
personally I would not use any of the stuff mentioned. swiftech makes a good coolant, and koolance 702 clear is a good coolant. I use a 20% prestone (green) antifreeze, with a 80% distilled water mix. I have been using this for over 20 years now and I have never had a issues with it.
for what ever reason swiftech has made some really good kits in the past. I personally own two H2O quite power systems, these systems are over 20 years old today, and I still use the PC cases that came with the kit. thank you swiftech, for building products that last.
Can we add products yet?
I've got the X3 H360 with a CPU unit only. What pump speed would be best for heat dissipation?
Gamer
I got a CPU+GPU loop of a 360X3 pump runs @1800-1900 on idle and set to run 100% "APROX. 3000RPM" @ 65 degrees.
With the H360 X3 can I use my noise blocker fans instead of there's and just have the cpu showing its RGB and use there controller/splitter to control the color of the cpu block
Shooting down fallacies
The only way to figure that out is by testing your specific build. There is no magic number, as it will vary greatly from build to build.
Set the pump and fans at full speed and heatsoak the loop using a consistent stress test. Once stabilized, back down the speed of the pump by 250 rpm and wait ten minutes. Repeat this until you see a temperature rise. Once you see a temp rise, raise the speed of the pump by 250 rpm. This will set you at your minimum speed without any loss of performance.
Yes.
Fantastic, that gives me a great point of comparison, ta
I understand, having a method to solve for pump speed will allow me to optimize that. Much appreciated :)
Gamer
Hmm h360 x3 + 2 additional 360 rads + Lian li front distro + cpu and 1 gpu block?
2nd radiator will just take up space in my opinion, but what do i know i aded a single 240 as exhaust and saw no difference
I Like Beer
Fans on low + looks 😉
011 dynamic has 3 360 rad mount locations, want to use them, the h100i although good cannot maintain silent operation with an OC with a cpu demanding title. I want dead silence lol
I’m also selling the swift tech block and using the Corsair XC7 block, only reason I got the H360 is to help me hide stuff. I want the only visible thing to be lines running to the cpu,
Gamer
I guess if you go for a Color Theme and paint them, not sure how the 3000RPM pump will handle all that. Post it when it works out.
I Like Beer
Gamer
Swiftech says it’s ok.
mINE RUNS @ 1800 TO 1900 rpm all the way to 50C and it is silent, even @ 3000RPM it is still a slight buzz. Good luck and post this here when its done
I Like Beer
Gamer
I Like Beer
