Swifty MCR320 or XSPC RX360?
1907 Views 23 Replies 10 Participants Last post by  phaseshift
alright i'm torn between these two. Right now I'll be cooling my cpu only which will be the 965 BE c3 and in the future my 2x 5770. I can't decide! THE MCR320 is cheaper and does well on performance and the RX is more money but is reviewed as the better for quiet performance. Which would you guys recommend? Keep in mind that in the future when I do cool my 5770s that I will ad another 240 RAD in there.
1 - 20 of 24 Posts
I would go for the mcr320. It's smaller, cheaper, and nearly matches the performance of the rx360. I don't think the extra performance and space taken up by the rx360 justifies the extra cost.
If you can afford the RX360, go for it. It has way more cooling headroom than an mcr320 has. that being said, an mcr320 with the appropriate fans can cool your chip just enough. I don't think either RX360 or mcr320 will be able to handle 2 gpu's + cpu, you may want to invest in a second (dual?) radiator. or if you have space, buy both and use the mcr320 for GPUs and the RX360 for CPUs.
the MCR320 is a single pass, whereas the RX360 is a dual pass. It is the best performing radiator for its price, in the low-cfm dual-pass division.
yeah I do plan to get a dual when I cool the GPUs. What fans would you guys suggest for both of these RADS? If i go with the MCR320 that gives me a little more cash for a fan controller etc..In the long run I'm looking for the best bang for the buck and performs well and quiet!
You can't beat the price/performance of the mcr320. I would suggest some medium speed yate loons to go with it
. Goodluck on your decision cheers!
nope, both are dual pass... the RX is 3 rows of tubes versus the single row on the MCR320. RX is triple row dual pass, MCR is single row dual pass. Performance is about equal over 1400RPM, with the RX having the advantage at slower fan speeds. Either way you're going to get a good radiator.
XSPC: 8 FPI Absolute for low fans
PA:12 Mid and low
Swiftech:15 Mid
Anything over that is for higher fans.
Best bang for buck is a Swiftech since it is cheap, efficient and is made for a budget build.
skinee!! wow you visted my thread! haha what fans would you recommend for both of the rads?
I use yate loons, but I'm cheap when it comes to fans. I've heard nothing but praise for Scythe S-Flex G's and Gentle Typhoons though.
I was loiking at the loons too low mid or high rpm types for the yate loons?
I use the high speed Yates on a MCR320. They perform well for me. I'm not bothered by the noise, and don't use a fan controller.
i can use low rpm fans also right i want a quiet setup
I would get the RX360 with some medium speed fans and a fan controller so you can turn them down if you want quiet.
Yes you can, but go with high with a fan control is better. If you need to cool the cpu more you just turn it up.
Sunbeam Rheobus Extreme for a fan controller... simple and plenty of wattage per channel.
skinnie on your rad you said you use the loons, what speed?
depends on the radiator and which machine.
I have Yate Low, Medium and High's floating around the lab and attached to radiators. I personally like the mediums, good air flow and low noise.
i think I'll go with the meds thanks, if I get a fan controller, and the fans have 3 pins will i still be able to control the fans?
1 - 20 of 24 Posts
