Not 100% sure how Fedora handles this, but it should be as easy as pulling the 1060, adding the 5600XT, and then deleting your xorg.conf. This assumes that you are running xorg and not wayland.
Unless Fedora is doing some whacky things you shouldn't really even need to remove the drivers. I would remove the nvidia drivers after adding the 5600XT, but I've had systems with mixed AMD NVIDIA cards, swapped cards, and every imaginable combination.
I'm not sure how Fedora packages Mesa, but outside of a few select scenarios Mesa's vulkan is better than amdvlk (AMDs standalone vulkan implementation).
I have been on Arch for many years, so unforunately I can't say for sure if it will be as simple on Fedora as it is on Arch.
