1 - 20 of 34 Posts
I have a budget of around 600...I will be switching out the motherboard processor and ram..But i'm clueless as to where to start I've never worked with intel before....<br />
<br />
Everything in my systems specs will be going into this build...I'm looking for a motherboard that supports full x16 bandwith for the GPU's. I'm also looking for two gigs of ram?<br />
<br />
I'm really not sure of where to start here?Any help will be greatly appreciated!
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819115003" target="_blank">E6600</a><br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813131025" target="_blank"> P5W DH Deluxe</a><br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820141211" target="_blank">PQI Turbo</a><br />
<br />
You need anything else?
Reactions: charliemack
you want two x16 slots right? Its gonna be hard with 600 with 2g RAM too.... unless you want something slow as hell. If you can settle for 1 x16 slot, go for the Gigabyte DS3 or S3, first 149$, second 110 or so. Both get good overclocks. and alot rides on whether or not you want to overclock, and a aftermarket HSF, do you already have one? is so, which one? answer and ill be happy to help out.
thats like 700, mabye go for the P5B Deluxe, the p965 chipsets can run crossfire now. and plus, the p5w has two pcie slots, but one is only pinned as a x4. (dosent make sense i know.) and then drop that processor down to the e6400 and then overclock.
<tr>
<div>
Originally Posted by <strong>charliemack</strong>
</div>
<div style="font-style:italic">wow thanks for the quickness! Does that motherboard support full 16x bandwith though?</div>
</td>
</tr>
</table>
</div>yes, but you won't get SLI with 16x though, all mobo can't give out the full 16x
Discussion Starter #7
<tr>
<div>
Originally Posted by <strong>Devilphalanx</strong>
</div>
<div style="font-style:italic">you want two x16 slots right? Its gonna be hard with 600 with 2g RAM too.... unless you want something slow as hell. If you can settle for 1 x16 slot, go for the Gigabyte DS3 or S3, first 149$, second 110 or so. Both get good overclocks. and alot rides on whether or not you want to overclock, and a aftermarket HSF, do you already have one? is so, which one? answer and ill be happy to help out.</div>
</td>
</tr>
</table>
</div>Yeah i'm water cooled put's down great temperatures with this processor at 2.7 it stays around 38c loard....I'm looking for the full 16x because of the two cards that i have..I'd like them to be used to their full capacity! I'd definitly like to overclock but i'm not trying to hit any crazy speeds with it!
<tr>
<div>
</div>
<div style="font-style:italic">thats like 700, mabye go for the P5B Deluxe, the p965 chipsets can run crossfire now. and plus, the p5w has two pcie slots, but one is only pinned as a x4. (dosent make sense i know.) and then drop that processor down to the e6400 and then overclock.</div>
</td>
</tr>
</table>
</div>He have SLI not Crossfire<br />
<br />
P5B Deluxe will run slower in SLI/CrossFire than the P5W DH
oh ****, sorry, yeah no boards can run the full x16 then. yeah, go for the e6400 then, the smaller L2 cache is not that much of a performance difference, and you can still overclock with that water really well.
wierd i heard that the 975x only runs cs at 8x 8x, and the p965 runs it at full x16 x16, oh well, i dont know about sli though
Discussion Starter #11
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813131031" target="_blank">http://www.newegg.com/Product/Produc...82E16813131031</a> <br />
<br />
What about this board? any good no good?
Not great for overclocking, you could spring for a good NB cooler though, for ocing the intel are the best. although for you and your sli, this looks to be the best option. (and by that, ghetto slapping a fan on there <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
There are currently no good ocing board for Conroe and Nvidia chipset
yeah so its up to him on how much he wants the oc or the two graphics cards. yeah, go for the e6600 and that board then, since you dont want to oc much with that. a little above your price range though
yeah but the e3400 is not as fast compared to the e6600, i suggest just making the jump to the e6600, because ocing is so limited on this board, and then you wont have to waste money on not using one of your gfx cards, and/or full potential, which would suck.
Discussion Starter #17
So this <br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16819115003" target="_blank">http://www.newegg.com/Product/Produc...82E16819115003</a><br />
<br />
And the motherboard i listed?<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813131031" target="_blank">http://www.newegg.com/Product/Produc...82E16813131031</a><br />
<br />
What about ram?
hrm, that OZC *EDIT: um, pqi turbo lol i misread* stuff mikey posted should be good I would recommend the memory i have in 2gigs if it didnt spike 100 dollars since i got it! 179-289 ouch! but yeah
<tr>
<div>
</div>
<div style="font-style:italic">So this <br />
<br />
<br />
<br />
<br />
What about ram?</div>
</td>
</tr>
</table>
</div>For roughly the same price, why don't you just get the P5W DH Deluxe and call it a day<br />
<br />
Use the PQI that i switched from OCZ
its really up to you dude, graphics higher bandwith, or saving money and overcloking on an intel board.
1 - 20 of 34 Posts
