You want a short and sweet answer or a long and nerdy one?
I think you want short: if its working, DONT TRY TO FIX IT
Originally Posted by Ropey Hello Bluemonster71, I disagree with leaving it alone. Your system performance might not be noticeable but you haven't compared it with the correct drivers yet. Did your system come with a system disk? If not, go to this ASUS site for your A8V driver downloads: http://support.asus.com/download/dow...Language=en-us Insert "A8V" (without the quotation marks) in the "Download" field. Choose "A8V" for mainboard. Choose the "Drivers" tab. Download the Ethernet (Marvel) Drivers = Marvell Yukon Gigabit Ethernet Driver V7.14.1.3. for 32Bit Windows. or Marvell Yukon Gigabit Ethernet Driver V7.31.1.3 for Windows 64bit XP/2003 for 64Bit Windows. Download the USB 2.0 Drivers = VIA USB 2.0 Host Controller Drivers V2.57 for Windows 98SE/ME/2000/XP Download the Via 4 in 1 Driver set = VIA 4 in 1 driver Package Service v4.51 Download the "Cool n Quiet" Driver (if you have an Athlon64, not if you have a Sempron) = AMD Cool''''''''n''''''''Quiet Driver package revision 1.1.0.0 for Windows XP. Expand each program as they are "zipped or archived" into a folder and run the setup utilty. If you don't know how to download or install the drivers you can contact me: [email protected] = msn [email protected] = yahoo [email protected] = aol 82202625 = icq and I will talk you through it. Gotta love trillian. Let's me have all messengers built into one platform. hth, R |
Originally Posted by Bluemonster71 Ahhhh thats the fun part. The Asus drivers under the driver section for my board are only for the Reltek audio drivers. But none for the board itself. |
Originally Posted by Ropey Yes, you need to install the 64 bit versions. Download the 4 - in 1 drivers here: http://www.viaarena.com/default.aspx...D=2&CatID=1080 R |
Originally Posted by metalkobra Actually no, its not the same difference, you cant mix 32 bit drivers with 64 bit OS's you need the proper drivers for the proper system. |
Originally Posted by Bluemonster71 Yep, Same ones I had already installed. But anywho chipset drivers doesn't pertain to my original question. Also the same thing appeared with xp32 so this just must be the way it is. |
