1 - 3 of 3 Posts
I just installed a program I have used before with no problems called Liquid Desktop from Isotope Graphics. When I did, my screen went all jarbled and I restarted... Ever since I cant get the system to boot, although I can in safe mode. I uninstalled that program but even now it will not restart in normal windows mode.<br />
<br />
Can anybody help?
Administrator
<tr>
<div>
Originally Posted by <strong>Fishinfan</strong>
</div>
<div style="font-style:italic">reformat?I think it might've messed a driver or something in the registry.</div>
</td>
</tr>
</table>
</div>This is easily fixed. <br />
<br />
When in safe-mode make sure that when you remove the program you have removed all Files and Folders associated with it. However do not try and tamper with the WINDOWS folder in this way. <br />
<br />
Also try running the System restore feature and see if you can restore your system to a previous state of healthy operation. <br />
<br />
If all fails i would do a repair install of windows by installing windows on same partition as windows is on now.
1 - 3 of 3 Posts
