DistributedCOM: ID 10016 The machine-default permission settings do not grant Local Activation permission for the COM Server application with CLSID {BC866CF2-5486-41F7-B46B-9AA49CF3EBB1} to the user MClouse-PC (S-1-5-21-3281789327-3073856418-1325888354-1000) from address LocalHost (Using LRPC). This security permission can be modified using the Component Services administrative tool.
Service Control manager: ID 7023 The HP CUE DeviceDiscovery Service service terminated with the following error: the specified module could not be found.
Application: ID 1000 Faulting application hl2.exe, version 0.0.0.0. time stamp 0x4445c334, faulting module filesystem_steam.dll_unloaded, version 0.0.0.0, time stamp 0x47e2d72b, exception code 0xc0000005, fault offset 0x02d3553e, process id 0x11a4, application start time 0x01ca19284e75749b.
SidebySide: ID 33 activation context generation failed for "C:/Program Files (x86)/AVG/AVG8/avglvea.dll" Dependent Assembly Microsoft.VC80.MFC,processorarchitecture="amd64",p ublickeytoken="1fc8b3b9a1e18e3b",type="win32",vers ion="8.0.50727.763" could not be found. Please use sxstrace.exe for detailed diagnosis
I dont see any Hardware error events
I have noticed that the DistributedCOM is 8444 of my errors. Beside it under the log segment it says "system"
