1 - 20 of 22 Posts
Well ive got the arctic 64 pro cooling hsf on my asus a8n32 mobo, running an x2 4200. The temps are around 40ish, it seems kinda hot to me. Any ideas?
Is that load or idle?
at idle mb is 40 degrees celsius, and cpu is 44 degrees. I have two 120 mm fans, i hooked them up to power supplies fan 4 pin molex, maybe i should hook them up to regular 4 pin molex for more power? Any suggestions? btw, i got temps in the asus probe. Mike
Discussion Starter #4
ive done research and found that they do run a lil warm, I really want to get some more as5 and reseat the hsf to see if that works.
Discussion Starter #5
does anyone think q-fan control on this mobo will help at all? let me know, Mike.
That does seem a little warm considering mine full load is lower then that. Have you checked their website to see if there is a bios update to recalibrate the sensors?
Discussion Starter #7
no but i'll check it out, thanks. Mike
How was the HS surface? Was it rough and did you lap it?
and how hot is it in the room your pc is in. ambient temps mean everything. if its 80f in your room, you will have a fun time getting your temps down.
Discussion Starter #10
yea dont have anything to figure out room temp, maybe I shoul lap the hsf and see if that helps. Thanks, Mike.
You could try removing your IHS if you are feeling a little adventurous. There is a really good guide to it on the site. I did it the other day and my CPU idles at 26*C with stock voltage and ambient temperatures of about 70*F or about 21*C.
You stated you wanted to use <b>more </b>as5, how much did you put on in the first place? You might have put on too much and the heat transfer is crap.
Also, those "Fan Connectors" on your PSU are pretty much worthless, unless you want a quieter pc. I have that same PSU, and plug your fans into "normal" 4 pin connectors, because the "fan connecters" REALLY SLOW DOWN your fans, trust me. My pc is loud now, but my temps dropped liek 6C from plugging them into normal 4pin psu connectors.
Discussion Starter #15
yes i was looking into that phantom, and on the topic of as5, only a pea size drop in the middle, i meant if i put more as5 on, im gonna clean the thermal paste off, lap my hsf, then reapply. Not put extra on haha. Mike
Discussion Starter #16
well i just did some serious cable managment, the psu only has one non fan 4 pin molex, so i just hooked up both fans and hd to that linking to each other. The pc still sounds the same, so I dunno if it worked or not. The next items I'll be getting is 1 more 120mm fan for the front intake and a fan controller. Hopefully running the fan controller will let me adjust fan even if i have to use the blue fan connector.
Discussion Starter #17
well temps seem to be a little better, gonna let it run and see if they stay. They are now around 30-33 degrees for the cpu and 35 degrees celsius for the system temps. Mike
Cool <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> Mine idles at about 37*C <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> i think i might need to d o a reseat...
Discussion Starter #19
yea its up to 36 now, so gonna have to lap hsf and reseat
Discussion Starter #20
whats the max idle this cpu can handle? reason im asking is I would like to get 2.4-2.6ghz out of it, but want to get the cooling situated before I do any oc'n.
1 - 20 of 22 Posts
