1 - 9 of 9 Posts
I have recently purchased a Compaq preario to start me off with an intel build (First Intel build!) with a view to replacing components as i can afford to (This may seem weird, why did i not by parts and build one? Well i had vouchers from an insurance company to spend in a certain shop and their components were very poor!) I have not upgraded anything yet and it is as it stands out of the box but seems to be under performing. Below i have noted the main components and several benchmark results.<br />
<br />
Intel Pentium D 940 @ 3.2 Ghz<br />
Asus GeForce 7500LE turbo cache 512Mb ( Core @ 550 Mhz, Mem @ 800 Mhz)<br />
2049 Mb DDR2 PC2-4300 @ 266 Mhz<br />
<br />
Super Pi Mod1.5 XS 1M Calculation = 44.266s<br />
AquaMark3 = 30,988<br />
3DMark03 = 2,841<br />
3DMark05 = 1,479<br />
3DMark06 = 607<br />
PCMark2002 CPU = 6,783, Memory = 14,144, HDD = 1318<br />
MetaBench = 3,251<br />
<br />
I feel that these scores are very below par for this system as my old system (skt 754 Athlon 64 3000+ @2.3Ghz, ATI Radeon 9250 128Mb, 1024Mb DDR PC-3200) even performed better in some of the tests and that had an extreemly poor graphics card. <br />
Should this be performing better or is it just that standard parts from compaq like the mobo and the RAM are letting it down?<br />
Any advice or comments would be great!<br />
Thanks<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Honestly, what you have ain't bringing any blistering heat either. It IS low though. I had a 6600 vanilla 450/500 and a P4 @ 3.8GHz and it pulled 45k in aquamark. <br />
<br />
<a href="http://img137.imageshack.us/my.php?image=aquamarkoc445sw9.jpg" target="_blank"><img src="http://img137.imageshack.us/img137/8782/aquamarkoc445sw9.th.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
EDIT: Hmmm let me see... yup 6600 at stock and 3.8Ghz. Looks like a 7500 and a 6600 are relatively comparable video cards. Scary.<br />
<br />
<a href="http://img87.imageshack.us/my.php?image=aquamark6600cr7.jpg" target="_blank"><img src="http://img87.imageshack.us/img87/5567/aquamark6600cr7.th.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a>
What I'm surprised about is your 3dmark06 score.. that seems super low to me. <br />
<br />
This is a shot in the dark, but do the compaqs come already set up nice? Like is there a 1:1 divider on the ram? Can you play with the BIOS at all?
Discussion Starter #5
There is zero tweaks in the bios but i am buying an asus p5b deluxe next Thursday so that shouild sort that problem. I will try re-installing the drivers and use driver cleaner but do i just use nVidia normal drivers for asus? Thats what i have been doing. I will get back to you after driver cleaning.<br />
Thanx!
I used to have a prescott 3.2 478 and do practicly the same score now with my conroe I made 71 K in auqamark 3<br />
<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Discussion Starter #7
Ive used driver cleaner and re installed latest nvidia driver and my aquamark3 score went up to 35,000 and my 3dmark03 score went from 2841 to 4356!!!!<br />
Thanks, dont know why it didnt work as good before and since i reinstalled the drivers my screen resolutions in windows make everything look smaller!<br />
Thanks again
There should be a jumper on your board to the right of your RAM i think,<br>
set it to 2-3 and then when you boot it goes straight to bios and you can OC! w00t works for me <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
1 - 9 of 9 Posts
