Since deciding to go with air cooling on my ASUS 8800GT 512Mb (and save the water cooling for my CPU) I have been looking at a lot of reviews for the Thermalright HR-03 GT and the Thermalright T-Rad2. However all the reviews I have read either has the HR-03 GT as the better option then the T-Rad2 or vice versa. I am not planning on running SLI at any point in the future though I do plan on fitting 92mm fans to which ever heat-sink I eventually buy.
Are the temperature reduction differences so small that it doesn't really matter? As both heat-sinks cost about the same.
Also whats a good quite fan to go on them?
