1 - 11 of 11 Posts
So my buddy wants to build his own pc and his budget is around $760 yeah i know thats a wierd budget lol but thats how much he has to spend lol anyways he wants to play BF3 with me...he plays on xbox now...he needs everything except monitor which is a Dell 21.5" @ 1680x1050, HDD, and DVD Burner.
this is what i have come up with so far let me know what u think
CPU - AMD FX 6100 - 149.99
MOBO - ASRock 970 Extreme 3 - 89.99
CASE - Cougar Solution Black Mid-Tower - 59.99
GPU - Sapphire radeon HD 6870 1GB - 164.99
PSU - Rosewill HIVE 550w - 69.99
RAM - Patriot Signature 8GB (2 x 4GB) - 37.99
Fans - Cooler Master 120mm Blue LED - 39.95 (7.99ea.)
Mouse - Logitech G300 - 33.99
Keyboard - Logitech G510 - 89.99
Fan Controller - Sunbeam Rheobus Extreme - 24.99
Totals out to 761.86
so just let me know what u guys think...thank you in advance
700
Way more powerful system for a few extra dollars! It would kill that system!
Edit: If he doesn't need an hdd he would be in budget.
I would honestly replace that with an i5 2500k build. that Fx 6100 is really not worth it.
He was on a tight budget and yes if you can squeeze a 2500k that would be best but I did make it right under your budget with no hdd and an far better setup.
If you get a 2500k you will need either a p67 or z68 mobo to unlock it so all the prices will go up. The i5 2400 would still be a better performer than a fx 6100 for sure.
Originally Posted by Pseudonymous View Post
700
Yup, that's a really huge "upgrade" from the OPs parts.
Edit: Do not buy a motherboard with H67 chipset. When Ivy Bridge is released, boards with P67 and Z68 will be able to upgrade aka future proof.
Go with a ASRock Z68 Extreme3 Gen3 instead (which is also future proof due to Gen 3 PCIe
Sent from my GT-I9100 using Tapatalk
Oh ok thats what i was telling hjm too do also (get 2500k) and he kept saying he would rather spend a lilttle less on cpu and mobo so he can get the keyboard mouse fans and fan controller.
Sent from my NXM726HN using Tapatalk
The CX 600 V2 is a serious downgrade from a Rosewill HIVE 550 (which has more power on 12V rails AND is modular).... for a $10 savings (and it's an 8-12 week return rebate too)..... nah, stick with the Rosewill PSU.
I was also about to tell your friend to run away screaming from that Rosewill PSU, but then I looked at the HS review, and it's not bad.. In fact, keep it. Semi modular, bronze, and with decent power output. Ripple and voltage suppression isn't quite SeaSonic grade, but it's entirely within acceptable levels.
Move to an Asrock P67 board, and the 2500k, and remind him that fan controllers and sparkly fans do not make the machine run faster, plus they're not expensive and can be added later.
1 - 11 of 11 Posts
