Source
Low, low-rider Titan has just introduced the FENRIR, a CPU cooler that is compatible with Core i7 processors. Codenamed TTC-NK85TZ, the cooler measures 156 x 124 x 107 mm and has four 8mm copper heatpipes in a 'Heat Pipe Direct Touch' mix, an aluminum heatsink and a 120mm Z-axis bearing fan which works at speeds between 800 and 2200 RPM (rotations per minute). Going from 17.2 to 39dBA in terms of sound output, the FENRIR has support for Intel LGA775, LGA1366 and AMD Socket AM2+, AM2, 940, 939, 754 CPUs. The cooler's pricing is yet unknown. ![]() |
