Team Fortress 2 Stress Test
5106 Views 18 Replies 9 Participants Last post by  Mootsfox
Hey guys, I found this earlier on the Steams Forums.
Basically a demo file of a 32 player server, with everyone having unlimited ammo, constantly firing their weapons, really stresses out your pc, good way to see and see how much the multi-core patch helps you
To use it, download the demo file and extract it and place it in steam\\steamapps\\your account name\\Team Fortress 2\\TF folder
First run the demo without the mutli-core patch, then with it. To enable multi-core go to Options > Video > Advanced > Multi-Core
Open TF2 and open the console and type "net_graph 1" to see your fps
Then "playdemo stress_test"
Here is the demo file.
http://rapidshare.com/files/210922646/stress_test.zip
Thanks to Ramzy on Steams forum's for doing this.
1 - 19 of 19 Posts
a lot of crashes happen because of this path tho
I haven't had any. :-D
It's worth it in my opinion.
Without:
With (55-65% average CPU usage):
i was playing on a server and people were crashing and i had like 4 crashes in 1 hr. it might be the server
What was the error?
crap, even with the multi-core enabled im getting like 20 fps.
I just tested it out using the "timedemo" command. The results are saved in "sourcebench.csv", for me at least.
Half-Life 2 Benchmark Results
demofile,frame data spreadsheet,frames/sec,framerate variability,totaltime (sec),width,height,numframes,dxlevel,backbuffer format,cmdline,driver name,driver desc,driver version,vendor id,device id,subsys id,revision,whqllevel,forcetrilinear,fastclip,shaderdll,sound,vsync,
stress_test.dem,stress_test_disabled.txt, 49.0,  3.6, 90.7,1680,1050,4444,gamemode,BGRA8888,"e:program files (x86)steamsteamapps*******team fortress 2hl2.exe"  -game tf -steam,ATI Radeon HD 3870 X2,0x1002,0x950f,0x25421002,0x0,disabled,disabled,DEFAULT,enabled,disabled,
stress_test.dem,stress_test_enabled.txt, 60.9,  5.5, 72.9,1680,1050,4444,gamemode,BGRA8888,"e:program files (x86)steamsteamapps********team fortress 2hl2.exe"  -game tf -steam,ATI Radeon HD 3870 X2,0x1002,0x950f,0x25421002,0x0,disabled,disabled,DEFAULT,enabled,disabled,
You guys arent doing proper tests
. I did some tests recording with rivatuner to show the real min FPS that i was getting. The first screen shot includes:
First line marker is multicore disabled with i7 920 at stock HT OFF. lowest minimum FPS marked.
Second line marker is multicore enabled with i7 920 at stock with HT OFF. lowest minimum fps marked.
And the second screen shot includes:
Multicore enable with i7 920 stock with HT enabled as well.... unfortunately HT sucks. Gotta love the 20-30% GPU usage
. Thanks for the test, +rep.
Well it doesn't take a genius to look at the net_graph command to see the increase in FPS with multicore enabed Auld
. But your method does provide the minimum FPS in each case.
Originally Posted by Bartmasta
sadly i've only got a dual core
should work for you too. Worked with my E8600 if I dont remember wrong! (this was with a command though)
Yup it will greatly increase the performance of a dual core as well, TF2 without the multicore support only uses 1 core. The old command to force multicore support was mat_queue_mode 2 but it was very unstable and caused the game to crash for me. This new update hasnt crashed me yet.
oooh so no crashes?
when I used that command, it crashed like every 20min -_-
Ooh nice. So is the option already implemented in the game or what?
Read the OP again.
when I type in playdemo stress_test I get
COM_CheckGameDirectory: game directories don't match (hl2 / tf)
Did you put the stress_test demofile into your tf folder?
1 - 19 of 19 Posts
