1 - 5 of 5 Posts
Because the network infrastructure in Israel is dumb, I can actually get 2 concurrent Internet connections going. One over VPN to my ISP, and one directly through the cable provider.
This means that I now have 2 adapters with 2 different IPs:
Local Area Connection - connected to the router, which gets an Internet IP through DHCP from the modem
VPN connection to ISP - over Local Area Connection
I want Windows to use both of those adapters to access the Internet. The Network and Sharing Center recognizes both of them as having Internet access.
I have a 12Mbps cap, but if I can team them I would effectively have 24Mbps with multithreaded downloads.
Another (better) option is to do the teaming on the router, which is running Tomato 1.27.
I don't think so. Bridging is "dumb" - it will just pass packets between them. I can bridge either of the WAN connections with the local VLAN to control through which connection packets go through, but I have 2 WAN IPs, so I need something that knows how to abstract that.
It seems to get it to work on the router all I have to do is install the bonding kernel module, but it's going to be a bit of a pain to compile a kernel for the router. I am also a bit wary of doing so because I have no way of fixing things should it not boot
I found this diagram of the WRT54Gv4/WRT54GL.
I have an additional interface, ppp0, which is connected to my ISP over vlan1. I added it to the diagram:
I'm not sure how bridging would work. Bridging just "joins" 2 physical networks into 1 logical network, passing packets between them.
It's a pretty bizarre setup in that internet traffic from vlan0 goes out over ppp0, but internet traffic from the router itself (i.e. wget http://overclock.net) goes out over vlan1.
There is actually a kernel module named bonding which does just this, but compiling the kernel for the router will be a pain and pretty risky
ifconfig output from the router:
ppp0 Link encap: Point-to-Point Protocol
inet addr:82.80.187.215 P-t-P:82.80.187.1 Mask:255.255.255.255
UP POINTOPOINT RUNNING MULTICAST MTU:1392 Metric:1
RX packets:1254 errors:0 dropped:0 overruns:0 frame:0
TX packets:1053 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:570470 (557.0 KiB) TX bytes:154823 (151.1 KiB)
vlan1 Link encap:Ethernet HWaddr 00:1A:92:7D:08:0B
inet addr:84.111.195.189 Bcast:84.111.195.255 Mask:255.255.252.0
UP BROADCAST RUNNING MULTICAST MTU:1392 Metric:1
RX packets:2673 errors:0 dropped:0 overruns:0 frame:0
TX packets:1091 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:778145 (759.9 KiB) TX bytes:217012 (211.9 KiB)
1 - 5 of 5 Posts
