Here are the components I got:
-Ultra Power Partner 325-Watt ATX Power Supply (ULT40063)
-245W Potted Peltier
-Luberex Dielectric Grease
-Silicone Conformal Coating - 12oz. Aerosol
-50x50mm Copper Cold Plate
-Swiftech H20-APEX "ULTRA" Series Liquid Cooling Kit, but with a Black Ice XtremeII Radiator instead of the swiftech made one. 1/2" ID tubbing.
I have another loop in the system colling the gpu and northbridge with a 120mm swiftech radiator. Both loops are using the same pump MCP655 but they dont cross each other in terms of heat. Most things are swiftech and from newegg or frozencpu.com
CPU=e6600.
MOBO=intel 975XBX
memory=PNY 6400 2 gb
PSU=XION 700 watt
Is this going to work on the e6600 cpu? Is it worth it concidering performance over electricity consumption or heat increase in the room?
CPU=e6600.
MOBO=intel 975XBX
PSU=XION 700 watt
