TEC Thermal Resistance?
1657 11
I have seen coolers that have a TEC between the CPU and the HSF and the TEC is activated only when the processor reaches a certain temperature, wouldn't the TEC add thermal resistance and give worse temperatures when not activated?
1 - 12 of 12 Posts
Those heatsinks have a heatsink base directly on the CPU. There's a TEC on TOP of that heatsink base. The TEC is cooled by another heatsink (basically).
You are correct though. A TEC not moving enough energy is an insulator.
You can sorta see here that the TEC is between two metal plates with heatpipes.
yes, not to mention Peltiers work both ways: Curent in = delta t AND delta t can = curent out.
not a good idea imo. I have seen setups that will vary the power which would be a good idea to keep condensation down.
Originally Posted by RockNRolla
If I put, say a 56W TEC on my GPU and an HR0-03, if I ran the TEC full time, would the temps go lower than with just the heatsink?
Your CPU would overheat in less than a minute and the TEC would fry.
gpu?
Your GPU would overheat in less than a minute and the TEC would fry.
ahhh. What wattage could I use with a GTX 285 (stock) and an HR-03 GTX with a high CFM fan to get "below-standard-air" temps?
For a GPU core, you would probably need a 200-300w TEC. Your HR-03 won't be able to handle the 300w+ load.
I always try to have a TEC at least twice the wattage as my OC'ed chips heat output, 3x is even better. You really want WC on any TEC if your OC'ing it, a HSF, unless it the size of a small state, isn't very effective. If you use a underpowered TEC you will run hotter then a HSF or WC'ing, to small a TEC and you can kill your chip from the heat, I don't know if you can set a shutdown temp for a GPU, if you can I would.
Really for a GPU I'd just do a hard core WC on it, if your volt modding it or doing insane clocks, and get a GPU dry ice/Ln2 pot for benching.
1 - 12 of 12 Posts
