[TechReport] A-Data unleashes half-terabyte SSD
706 Views 12 Replies 11 Participants Last post by  Alby
Consumer solid-state drives are quickly climbing in capacity. A-Data has announced a new 2.5" SSD that can store up to 512GB, putting it right up there with the latest and greatest mobile hard disk drives. Of course (and this is just us going out on a limb), the SSD will probably cost quite a bit more than its mechanical rivals.
A-Data rates the 512 XPG 2.5" SSD for top read speeds of 230MB/s and top write speeds of 160MB/s. Coupled with the 300MB/s Serial ATA interface and near-instantaneous access times, that should translate into fairly snappy performance. (For the record, Intel's super-fast X25-E Extreme SSD has respective read and write ratings of 250MB/s and 170MB/s.)
Sadly, while A-Data flaunts photos of the SSD's packaging and the "dashing, durable lightweight aluminum casing," it neglects to mention pricing and availability details.
This isn't the only company to announce a 512GB SSD. Last year, Toshiba revealed plans to start production of a 512GB 2.5" solid-state in the second quarter of this year. The Toshiba THNS512GG8BB uses 43nm multi-level-cell NAND flash memory and has performance ratings of 240/200MB/s.
source
That's amazing that they can now pack that much storage into a 2.5" form factor. Plus, two of these in RAID 0 will be WAY smaller than the OCZ one we saw in the news yesterday.
1 - 13 of 13 Posts
Has the stuttering been fixed yet?
I know it had to do with the controller, j-micron? something like that? Do drives still use it?
I think a few do.
~Gooda~
For a second there thought it said "SD", since it does look similar. We won't be seeing 512GB SD cards until next year :/
Still, this is good, since I'm sure the cost/GB will be much less than intel's.
If Flash memory keeps increasing in capacity it could be not very long at all before SSD have both greater capacity and performance then standard HDD. This is more impressive to me then OCZ's 1tb drive because, as far as I can tell, this is just one SSD with 512gb capacity rather then 2 or more smaller SSD linked together with a RAID controller. Awesome stuff. Future hard drives may come in multi level SSD rather then multiplatter, and have incrediable scaling performance too. I want one.... but can't afford. Maybe next year!
The speed at which they are increasing capacity seems to be running an exponential curve. First it was incredibly slow, not it is picking up incredible speed. I'm starting to finally get excited for SSD.
SSDs are still $180 for 64GB though. You'd think that will all of these advances in SSD tech somebody would realize that they need to make them affordable first.
No freaking doubt, it took decades for traditional hard drives to reach one Tb, now SSD's pull it off in what, two years?
That's not that bad considering the speed boost you get out of these things, and plus, I'm sure that later this year, we'll see an explosion of ssds, Western Digital is supposed to enter the ssd market soon too, and i'm sure there are countless other companies that are eyeing the prospect of ssds.
I wonder if these things will be overclockable?
um... no.
New technology almost always moves from the top down. As the super high end continues to get more advanced, the lower end SSD will gradually drop in price. New production techniques designed to get more overall performance often benefit consumer end as well. Particularily in die shrinks and such. The small these SSD get, the cheaper they will eventually be.
Originally Posted by ImmortalKenny
Psh
http://www.engadget.com/2009/01/10/p...-2-5-inch-ssd/
Originally Posted by beanbagofdoom
Amazing size difference compared to the OCZ 1TB drive
The OCZ drive is four 256GB SSDs. If A-Data wants to they could put four of their 512GB drives and get 2TB.
1 - 13 of 13 Posts
