[TechReport] A quick first look at USB 3.0 performance
3585 Views 60 Replies 36 Participants Last post by  sLowEnd
USB 2.0 is so last millennium. No, seriously. We've had the specification since the year 2000, which is technically the previous millennium. Given how quickly the PC industry moves, though, it might as well have been a full millennium ago. Back in 2000, Intel was pushing Pentium III CPUs, 3dfx was still selling graphics processors, and Windows XP was a year away. Things have certainly changed since the so-called Hi-Speed USB spec was released, and its 480Mbps peak data rate has been grossly inadequate for quite some time now.
source
Very good numbers. Now we just have to wait for the hardware to become more standard and pricing to be where USB 2.0 products are now...
1 - 20 of 61 Posts
Wow that's, amazing how long USB 2.0 has been around. Just goes to show how useful it is.
oh excellent!
FINALLY USB wont bottleneck external HDDs (that support USB3 that is).
yeah nice but...
is 480mb/s inadequate, really?
i understand USB need in HDs, but id rather not bother with anythings else, like cameras, or ipods. Until prices come down to USB 2.o levels, im not interested. Except for Hds that is. Really looking forward to that
Originally Posted by Stewart=B View Post
yeah nice but...
480mb/s is peak, that means you will almost never see that performance. Look at the graph in the OP, it was running at 37Mb/s.
So this is basically as fast as e-sata, I don't know why devices just didn't adopt that?
EDIT: Just googled e-sata and found that it doesn't have the ability of powering the devices its using, that would be why.
e-sata doesnt supply power?
boom shakalaka
USB 3.0 is going to be great once it is standard on everything.
Because of SATA 6.0Gbps.
SATA 6Gbps supports power over eSATA, it's all a matter of implementing it.
USB 3.0 has a tech spec speed of 4.8gbps, or 600MB/s. If we follow that it has about the same efficiencies as USB 2.0, we could expect a real-world maximum speed of 370MB/s.
That should be sufficient for quite some time, I do believe.
All I have to say is, IT'S ABOUT TIME!
480Mb/s = 60MB/s (1 Byte (B) = 8 bit (b))
The graph shows that it was running at 37MB/s (Megabyte not Megabit )
Wow. I'll definitely wait for the new Gigabyte AMD boards to come out with 3.0 support before I finish my build.
USB 2.0 is 480 megabits per second, not bytes. 480Mbps is equal to 60MB/s.
some motherboards do support "power-over-eSATA". But most externals use either a power brick, or an additional USB cabl purely for power.
I hadnt seen one of those yet cheese. Then again hadnt looked at PC stuff in a fair while lol.
Had only seen esata ones with power bricks/usb power cables like you said.
Must be relatively new?
Isn't USB 3.0 severely limited by bus speeds?
Thank you. I thought most people on this forum knew the difference between Mbps and MB/s. Obviously not.
External HDDs are already bottlenecked by their own speeds.
That's why SSDs are around.
1 - 20 of 61 Posts
