temp for san diego 3700
579 10
i just slightly oc'd my 3700 san diego to 2.4 and ran prime95 w/ an avg hi temp of 48-49 C. just wondering if that is too high?
1 - 11 of 11 Posts
· Premium Member
Seems a little high but anything below 50*C at load is fine (of course, lower is always better). I personally prefer to keep mine at 40-45*C. Are you running stock voltages? What kind of cooling do you have on it?
· Premium Member
Get a TT Big Typhoon... the fan is not all that great but good.
A better fan and it will keep you cool
· Premium Member
Many forum members are using the BT and having excellent results with it.
Discussion Starter · #8 ·
would the big typhoon fit in my motherboard fine? i hear its pretty dang big and can be a beast to install.
what about the zalman 7700? anybody got an opinion about it?
oh and melcar, yea, im just using stock voltage....i think 1.5
· Premium Member
The typhoon is fine for your 3700+. The zalman 7700 doesn't cool nearly as well. i gave my venice 1.8v and it never went above 45*C.
Don't worry about it fitting the mobo - worry about the case. I will fit in most standard ATX cases.
1 - 11 of 11 Posts
